Confirming Switch Specifications
Preparing to Install the Switch
Install the Switch in the Rack
Finish the Switch Installation
Connecting to the Service Processor
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Configuring SEFOS User Privileges
Change a SEFOS User Privilege Level
Check Switch Status (Oracle ILOM)
See Front Panel Components for the location of the serial management port on the switch.
This action establishes the connection between the terminal device and Oracle ILOM.
The Oracle ILOM login prompt appears.
SUNSPnnnnnnnnnn login:
The default user is root and the default password is changeme.
Once you have successfully logged in, Oracle ILOM displays the default command prompt.
See Connect to SEFOS.
