Confirming Switch Specifications
Preparing to Install the Switch
Install the Switch in the Rack
Finish the Switch Installation
Connecting to the Service Processor
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Configuring SEFOS User Privileges
Change a SEFOS User Privilege Level
Check Switch Status (Oracle ILOM)
The switch uses several configurable sensors and indicators to monitor switch power, voltage, and temperature. The switch includes replaceable component sensors that generate entries in the SEL when the sensor crosses a threshold. Many of these readings are used to adjust the fan speeds and perform other actions, such as illuminating LEDs and powering off the switch.
You can also configure these sensors to generate IPMI PET and SNMP traps, as described in the Sun Integrated Lights Out Manager (ILOM) CLI Procedures Guide.
Caution - Do not use any interface other than the Oracle ILOM CLI or web interface to alter the state or configuration of any sensor or LED. Doing so could void your warranty. |
You can view the system monitoring sensors and indicator parameters from the Oracle ILOM CLI or web interface.
Sun Integrated Lights Out Manager (ILOM) Concepts Guide
Sun Integrated Lights Out Manager (ILOM) 3.0 Management Protocols Reference Guide
