Go to main content
SPARC T5-1B Server Module Service Manual
Exit Print View
Updated: February 2019
Replace the Cover
Perform this procedure after completing installation or servicing of components inside the server module.
  1. Set the cover on the server module (panel 1).
    The cover edge hangs over the rear of the server module by about .5 in. (1 cm).
    image:FIgure shows how to attach the top cover to the server module.
  2. Slide the cover forward until it latches into place (panel 2).
  3. Install the server module into the modular system chassis.
    See Install the Server Module Into the Modular System.
Related Information
