Go to main content
SPARC T5-1B Server Module Service Manual
Exit Print View
Updated: February 2019
Remove a Drive or Drive Filler
  1. Identify the drive you plan to remove.
    See Determine Which Drive Is Faulty.
  2. Prepare the drive for removal by performing one of these steps:
    • Take the drive offline.
      The exact commands required to take the drive offline depend on the configuration of your drives. For example, you might need to unmount file systems or perform certain RAID commands.
      One command that is commonly used to take a drive offline is the cfgadm command. For more information, refer to the Oracle Solaris cfgadm man page.
    • Shut down the Oracle Solaris OS.
      If the drive cannot be taken offline, shut down the Oracle Solaris OS on the server module. See Shut Down the OS and Host (Commands).
  3. Verify whether the blue drive Ready to Remove LED is illuminated on the front of the drive.
    See Drive LEDs. The blue LED will be illuminated only if the drive was taken offline using cfgadm or an equivalent command. The LED will not be illuminated if Oracle Solaris was shut down.
  4. Remove the drive.
    1. Push the latch release button on the drive (panels 1 and 2).
      image:Figure shows removal of a drive.
    2. Grasp the latch and pull the drive out of the drive slot (panel 3).
  5. Install a drive or drive filler.
    See Install a Drive or Drive Filler.
Related Information
