This procedure applies to any of the form factors of FEM cards that are supported by this server module.
See Remove a FEM.
See FEM Configuration.
If the card has rubber bumpers you can press directly on them to seat the card into the connectors.
If you are finished servicing components, see Returning the Server Module to Operation.
If you are servicing additional components, see Component Task Reference.
