The serial number of the server module is located on a sticker on the RFID tag that is mounted in the center of the front panel. See Front and Rear Panel (Service). However, this label is not present on a server module that has been moved into a new enclosure assembly. You also can type the Oracle ILOM commands to display the number.
Through the CMM, type.
-> show /CH/BL9/System component_serial_number /CH/BL9/System Properties: component_serial_number = 1214NN0304
Through the server module, type.
-> show /SYS product_serial_number /SYS Properties: product_serial_number = 1219NN3024
