Go to main content
SPARC T5-1B Server Module Service Manual
Exit Print View
Updated: February 2019
Locate the Server Module
Use this procedure to illuminate the server module's Locator LED so that you can locate the server.
  1. Log into Oracle ILOM.
    See Log Into Oracle ILOM (Service).
  2. Perform one of these commands according to the way that you logged into Oracle ILOM:
    • Through the CMM, type.
      -> set /Servers/Blades/Blade_5/System locator_indicator=on
      Set 'locator_indicator' to 'on'
    • Through the server module, type.
      -> set /System locator_indicator=on
    The Locator LED on the server module blinks.
  3. Identify the server module with a blinking white LED.
  4. Once you locate the server module, press the Locator LED to turn it off.
    Note - Alternatively, you can turn off the Locator LED by typing the Oracle ILOM set /System locator_indicator=off command.
Related Information
