Managing
SPARC Host Domains
Oracle ILOM provides a set of host domain properties that
enable system administrators to view logical domain configurations
presently set on a host SPARC server, as well as set host domain
properties for auto-boot and boot guests.
The Oracle ILOM host domain properties are viewable and configurable
from the Oracle ILOM CLI and web interface. For more details about
these properties, see the following tables:
Table 73 View Logical Domain Configurations Detected for Host SPARC
Server
Domain Configurations (read-only) |
Oracle ILOM displays a list of logical
domain configurations detected on the host operating system.
Oracle saves the detected logical domain configurations in non-volatile
memory and updates the listing as changes occur. |
Table 74 Host Domain Configurable Properties for Host SPARC Server
Auto-Run
(auto-boot=) |
Enabled |
Enabled |Disabled
When the property for Auto-Run is enabled, the OpenBoot setting for
auto-boot is enforced after the next domain
reset.
When the property for Auto-Run is disabled, automatic booting is prevented and the host
control domain will stop at the OpenBoot OK prompt upon the next
domain reset.
CLI Syntax for Host Domain Auto-Run:
For single-server SP, type:
set /HOST/domain/control auto-boot=enabled|disabled
For multi-domain server SP, type:
set /Servers/PDomains/PDomain_n/HOST/domain/control
auto-boot=enabled|disabled |
Boot Guests
(boot_guests=) |
Enabled |
Enabled |Disabled
When the property for Boot Guests is enabled, Oracle ILOM boots
the guest domains at the next server power-on or reset.
When the property for Boot Guests is disabled, the configured guest
domains are prevented from booting upon the next server power-on
or reset.
Note -
The boot_guests property automatically
reverts to Enabled (default property) after the server resets.
CLI Syntax for Host Domain Boot
Guests:
set /HOST/domain/control boot_guests=enabled|disabled
boot_guests=enabled|disabled |
