Requirements
for Using the Oracle ILOM Storage Redirection CLI
The following requirements must be met prior to using the
Oracle ILOM Storage Redirection CLI for the first time:
Table 57 Requirements for Using Oracle ILOM Storage Redirection CLI
JRE 1.5 environment |
The storage redirection
service and client are Java Web Start applications that require
the installation of the Java Runtime Environment (1.5 or later)
on the local client system.
To download the latest Java Runtime Environment (JRE), see http://java.com. |
Register 32-Bit JDK Plug-in
and Start Storage Redirection Service |
service must be installed locally or set to run from the Oracle ILOM
web interface.
The 32-bit JDK Java plug-in must also be registered with the
local client web browser.
Related Information:
Install Storage Redirection
Client |
After registering the 32-bit
JDK plug-in with the local client web browser and starting the storage
redirection service for the first-time, the storage redirection
client must be installed on the local client system.
User Roles |
A Console (c)
role is required in Oracle ILOM to launch and use the Oracle ILOM Storage
Redirection CLI. |
Communication TCP/IP Port Required |
The Oracle ILOM Storage Redirection CLI,
by default, uses TCP/IP port: 2121 to communicate with the host
server.
