Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 3.2.x
Exit Print View
Updated: November 2019
Disable Alert Notification (IPMI PET, SNMP, or Email)
The following procedure provides instructions for disabling a configured alert notification using the Oracle ILOM CLI and web interface. For instructions for configuring and testing alert notifications from an SNMP application client, see Manage Component Information and Email Alerts (SNMP) in Oracle ILOM Protocol Management Reference for SNMP and IPMI Firmware Release 3.2.x.
Before You Begin
  • Admin (a) role is required in Oracle ILOM to modify alert notification properties.
  • To disable the configuration of an alert notification, do the following:
    • Web:
      Click ILOM Administration > Notifications > Alerts, click a configured Alert ID, and then click Edit. In the Level list box, click Disable, and then click Save.
      A successful or failed status message appears.
    • CLI:
      Type the following to disable a configured alert notification:
      set /SP|CMM/alertmgmt/rules/n level=disable
