Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 3.2.x
Exit Print View
Updated: November 2019
Reset Zoning Allocations to Factory Defaults (CLI)
Before You Begin
  • Admin (a) role privileges are required in Oracle ILOM to modify Sun Blade Zone Manager properties.
Caution
Caution  -  Use this procedure only if you want to erase all currently saved SAS zoning allocations in Oracle ILOM.
  1. Navigate to /STORAGE/sas_zoning in the CMM CLI by using the following command:
    -> cd /STORAGE/sas_zoning
  2. To erase all saved resource allocations and reset the Sun Blade Zone Manager to factory defaults, type:
    -> set reset_access_action=true
    If the Zone Manager is disabled, you will get the following warning:
    set: The CMM is not the SAS Zone Manager
    If you receive this message, enable Zone Manager and re-issue the reset command. For details, see Access and Enable Sun Blade Zone Manager .
