Redirecting
Host Output to Rear VGA Port
Note - The policy for redirecting host output to a rear VGA
port is not available on all Oracle servers. Also, the front and
rear VGA ports on an Oracle server cannot be utilized simultaneously.
On some Oracle servers, Oracle ILOM provides a policy that
enables you to redirect the host output to a VGA port on the rear
panel of the server. By default, this policy is disabled and is
only configurable from the Oracle ILOM CLI. For further details about
setting this policy in Oracle ILOM CLI, see the following table.
Table 81 VGA Rear Port Property for Redirecting Host Output
VGA_REAR_PORT= |
disabled |
disabled |enabled
disabled – When
disabled, host output is prevented from being redirected to the
VGA port on the rear panel of the server.
enabled – When enabled, host output is
redirected to the VGA port on the rear panel of the server.
CLI Syntax for VGA Rear Port:
set /SP/policy VGA_REAR_PORT=disabled|enabled |
