Go to main content
Oracle® ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 3.2.x
Exit Print View
Updated: November 2019
Input Format for IPv4 and IPv6 Addresses
Oracle ILOM accepts the following input format for IPv4 and IPv6 addresses.
Address
Input Format
IPv4 (32 bit)
Use a four dotted-decimal number: n.n.n.n
Example: 192.0.2.0
IPv6 (128 bit)
When entering an IPv6 address or Link-Local IPv6 address, the address must be enclosed within brackets to work correctly. However, when you specify an IPv6 address to log in to Oracle ILOM using SSH, do not enclose the IPv6 address in brackets.
Examples:
  • IPv6 address: [2001:db8:0:0:0:0:0:0/32]
  • IPv6 address using SSH and root account: ssh root@2001:db8:0:0:0:0:0:0/32
  • Link-Local IPv6 address: [fe80::214:4fff:feca:5f7e/64]
