Understanding the Installation
Understanding Management and Power Cabling
Management Connection Overview
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
This table lists the tasks to perform for switch installation. Before you begin, answer these questions:
Are you installing one switch or two switches?
Are you orienting the switches with power supplies on the cold aisle or with data connectors on the cold aisle?
Is the installation into a Telco form factor rack?
How you answer these questions identifies variances from a standardized installation, and these differences are addressed in the installation procedures.
