Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Installation Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Management Connection Overview
NET MGT Port
SER MGT Port
Power Cord Specifications
Understanding Data Cabling
SFP+ Data Cable Overview
10GBASE-T Data Cable Overview
Data Cable Cautions
Data Cable Guidelines
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Glossary
Index
Note - Perform this procedure only if you are installing the switch with the data connectors on the cold aisle and the power supplies on the hot aisle.
  1. Identify the prerequisite and subsequent installation tasks that you must perform in conjunction with this procedure.
    See Installation Task Overview.
  2. Bring the data cables connectors that are to attach to the switch to the data connector end of the switch.
    Note - Do not attach the cables at this time.
  3. Sort the cables into two side-by-side groups (four groups for dual-switch configurations) that approximate the locations where the data cables attach on the data connector end of the switch.
    Use hook and loop straps to bundle the cables.
  4. Pass the data cables through the front support.
    1. Align the front support to the data connector end of the switch.
      The rolled top and bottom edges of the front support point away from the switch.
      Note - Do not attach the front support at this time.
    2. Pass the left-most bundle of data cables through the left-most opening of the front support.
      image:Figure shows moving the data cables through the front support.
    3. Pass the left-of-center bundle of data cables through the left-of-center opening of the front support.
    4. Pass the right-of-center bundle of data cables through the right-of-center opening of the front support.
    5. Pass the right-most bundle of data cables through the right-most opening of the front support.
  5. Pass the data cables through the smaller air duct.
    1. Align the air duct to the data connector end of the switch.
      The mounting tabs of the air duct orient away from the switch.
      Note - Do not attach the air duct at this time.
    2. Pass the left-most bundle of data cables through the left opening of the air duct.
      image:Figure shows moving the data cables through the air duct.
    3. Pass the left-of-center and right-of-center bundles of data cables through the center opening of the air duct.
    4. Pass the right-most bundle of data cables through the right opening of the air duct.
  6. Connect the data and management cables.
    See Attach Data and Management Cables
  7. Attach the small air duct and front support.
    See Install the Air Duct and Front Support.
Related Information
