Go to main content
SPARC T7-1 Server Service Manual
Exit Print View
Updated: February 2019
Extend the Server to the Service Position
You can service the following components with the server in the service position:
  • Drives or fillers
  • DVD drive
  • Power supplies
  • Fans
  • Memory risers
  • DIMMs
  • PCIe cards
  • SPM
  • eUSB drive
  • Battery
Note -  You can replace the drives and rear power supplies without extending the server into the service position.
  1. Verify that no cables will be damaged or will interfere when the server is extended.
    Although the CMA that is supplied with the server is hinged to accommodate extending the server, you should ensure that all cables and cords are capable of extending.
  2. From the front of the server, release the two slide release latches.
    Squeeze the green slide release latches to release the slide rails.
    image:Figure showing the location of slide release latches.
  3. While squeezing the slide release latches, slowly pull the server forward until the slide rails latch.
Related Information
