Go to main content
SPARC T7-1 Server Service Manual
Exit Print View
Updated: February 2019
Power On the Server (System Power Button)
Caution
Caution  - Do not operate the server without all fans, component heat sinks, air baffles, fillers, and the cover installed. Severe damage to server components can occur if the server is operated without adequate cooling mechanisms.
  1. Verify that the power cords are connected and that standby power is on.
    Shortly after power is applied to the server, the SP OK/Fault LED blinks as the SP boots. The SP OK/Fault LED is illuminated solid green when the SP has successfully booted. After the SP has booted, the Power OK/LED on the front panel begins flashing slowly, indicating that the host is in standby power mode.
  2. Press and release server power button on the server front panel.
    You might need to use a pointed object, such as a pen or pencil.
    When main power is applied to the server, the main Power/OK LED begins to blink more quickly while the server boots and lights solidly once the operating system boots.
    Each time the server powers on, POST can take several minutes to complete tests.
Related Information
