Perform one of the following
tasks based on your verification results:
If the previous steps
did not clear the fault, see Detecting and Managing Faults for
information about the tools and methods you can use to diagnose
component faults.
If the previous steps indicate that no faults have
been detected, then the component has been replaced successfully.
No further action is required.
