Table 73. Business Component Methods Syntax Summary
ActivateField Method |
Allows queries to retrieve data for the specified field. |
var myBusComp; myBusComp.ActivateField(fieldName);
ActivateMultipleFields Method |
Allows queries to retrieve data for the fields specified in the property set. |
var myBusComp; myBusComp.ActivateMultipleFields(oPropSet);
Associate Method |
Creates a new many-to-many relationship for the parent object through an association business component. |
var myBusComp; myBusComp.Associate(whereIndicator);
BusObject Method |
Returns the business object that contains the business component. |
var myBusComp; var busObject; busObject = myBusComp.BusObject();
ClearToQuery Method |
Clears the current query and sort specifications on the business component. |
var myBusComp; myBusComp.ClearToQuery();
DeactivateFields Method |
Deactivates every currently activated field. |
var myBusComp; myBusComp.DeactivateFields();
DeleteRecord Method |
Removes the current record from the business component. |
var myBusComp; myBusComp.DeleteRecord();
ExecuteQuery Method |
Retrieves a set of BusComp records. |
var myBusComp; myBusComp.ExecuteQuery(cursorMode);
ExecuteQuery2 Method |
var myBusComp; myBusComp.ExecuteQuery2(cursorMode, ignoreMaxCursorSize);
FirstRecord Method |
Moves to the first record in the business component. |
var myBusComp; var bIsRecord; bIsRecord = myBusComp.FirstRecord();
FirstSelected Method |
Moves to the first record of the multiple selection in the business component. |
var myBusComp; var bIsMultipleSelection; bIsMultipleSelection = myBusComp.FirstSelected();
GetAssocBusComp Method |
Returns the association business component. |
var myBusComp; var AssocBusComp; AssocBusComp = myBusComp.GetAssocBusComp();
GetFieldValue Method |
Returns a value for the field specified in the argument. |
var myBusComp; var sValue; sValue = myBusComp.GetFieldValue(FieldName);
GetFormattedFieldValue Method |
Returns a formatted value for the field specified in the argument. |
var myBusComp; var sValue; sValue = myBusComp.GetFormattedFieldValue(FieldName);
GetMultipleFieldValues Method |
Returns a value for the fields specified in the property set. |
var myBusComp; myBusComp.GetMultipleFieldValues(oFields, oValues );
GetMVGBusComp Method |
Returns the MVG business component associated with the field specified in the argument. |
var myBusComp; var MvgBusComp; MvgBusComp= myBusComp.GetMVGBusComp(FieldName);
GetNamedSearch Method |
Returns the named search specification specified in the argument. |
var myBusComp; var sValue; sValue = myBusComp.GetNamedSearch(SearchName);
GetPicklistBusComp Method |
Returns the pick business component associated with the field specified in the argument. |
var myBusComp; var pickBusComp; pickBusComp = myBusComp.GetPicklistBusComp(FieldName);
GetSearchExpr Method |
Returns the current search expression. |
var myBusComp; var sExpr; sExpr = myBusComp.GetSearchExpr();
GetSearchSpec Method |
Returns the current search specification for the field specified in the argument. |
var myBusComp; var sSpec; sSpec = myBusComp.GetSearchSpec(FieldName);
GetUserProperty Method |
Returns the value for a property name specified in the argument. |
var myBusComp; var sValue; sValue = myBusComp.GetUserProperty(propertyName);
GetViewMode Method |
Returns the visibility mode for the business component. |
var myBusComp; var iMode; iMode = myBusComp.GetViewMode();
InvokeMethod Method |
Calls the specialized method named in the argument. |
var myBusComp; var sReturn; sReturn = myBusComp.InvokeMethod(methodName, methodArg1, methodArg2,..., methodArgn);
LastRecord Method |
Moves to the last record in the business component. |
var myBusComp; var iReturn; iReturn = myBusComp.LastRecord();
Name Method |
Returns the name of the business component. |
var myBusComp; var sName; sName = myBusComp.Name();
NewRecord Method |
Adds a new record to the business component. |
var myBusComp; myBusComp.NewRecord(whereIndicator);
NextRecord Method |
Moves to the next record in the business component. |
var myBusComp; var bFound; bFound = myBusComp.NextRecord();
NextSelected Method |
Moves to the next record of the current multiple selection. |
var myBusComp; var iReturn; iReturn = myBusComp.NextSelected();
ParentBusComp Method |
Returns the parent business component. |
var myBusComp; var parentBusComp; parentBusComp = myBusComp.ParentBusComp();
Pick Method |
Places the currently selected record in a picklist business component into the appropriate fields of the parent business component. |
var myBusComp; myBusComp.Pick();
PreviousRecord Method |
Moves to the previous record in the business component. |
var myBusComp; var iReturn; iReturn = myBusComp.PreviousRecord();
RefineQuery Method |
Refines a query after a query has been executed. |
var myBusComp; myBusComp.RefineQuery();
SetFieldValue Method |
Assigns a new value to the named field for the current row of the business component. |
var myBusComp; myBusComp.SetFieldValue(FieldName, FieldValue);
SetFormattedFieldValue Method |
Accepts the field value in the current local format and assigns the new value to the named field for the current row of the business component. |
var myBusComp; myBusComp.SetFormattedFieldValue(FieldName, FieldValue);
SetMultipleFieldValues Method |
Assigns a new value to the fields specified in the property set for the current row of the business component. |
var myBusComp; myBusComp.SetMultipleFieldValues(oPropSet);
SetNamedSearch Method |
Sets a named search specification on the business component. |
var myBusComp; myBusComp.SetNamedSearch(searchName, searchSpec);
SetSearchExpr Method |
Sets the search specification for the business component. |
var myBusComp; myBusComp.SetSearchExpr(searchSpec);
SetSearchSpec Method |
Sets the search specification for the specified field. |
var myBusComp; myBusComp.SetSearchSpec(FieldName, searchSpec);
SetSortSpec Method |
Sets the sort specification for a query. |
var myBusComp; myBusComp.SetSortSpec(sortSpec);
SetUserProperty Method |
Sets the value of the specified User Property. |
var myBusComp; myBusComp.SetUserProperty(propertyName, newValue);
SetViewMode Method |
Sets the visibility type for the business component. |
var myBusComp; myBusComp.SetViewMode(viewMode);
UndoRecord Method |
Reverses any uncommitted changes made to the record. |
var myBusComp; myBusComp.UndoRecord();
WriteRecord Method |
Commits to the database any changes made to the current record. |
var myBusComp; myBusComp.WriteRecord();
