Bug 15678657
Issue:
Upon inserting the adapter into the chassis of a system, the system shows the adapter in the online state, as if the adapter has been configured, even though you did not press the Attention button on the adapter (which is a necessary step for adapter configuration). In some instances, the adapter then goes offline, without any intervention from you, the user.
Workaround:
This might occur during installation if you insert the adapter quickly into the chassis, and at an angle, causing the Attention button to become depressed and to potentially remain stuck in the On position. To avoid this from occurring, follow the installation instructions in this guide and take your time when installing the adapter into a chassis. If you install the adapter smoothly into the chassis, the Attention button does not get stuck in the On position.
