Go to main content
Sun Storage 10 GbE FCoE ExpressModule Converged Network Adapter From QLogic Installation Guide For Adapter Models SG-EMFCOE2-Q-SR, SG-XEMFCOE2-Q-SR, SG-EMFCOE2-Q-TA, SG-XEMFCOE2-Q-TA, and 7101682
Exit Print View
Updated: January 2017
FCIO_RESET_LINK Error Message Occurs After Issuing the luxadm -e forcelip Command
Bug 15632822
Issue:
You might encounter this error message after issuing the luxadm -e forcelip command from a system with the following configuration:
  • Oracle Solaris 10 10/09 OS running
  • Adapter installed and connected to a Brocade 8000 FCoE switch
  • Brocade 8000 FCoE switch connected to a tape zone on a FC SAN with an SL48-LTO4 FC tape library
If you issue the luxadm -e forcelip command upon the removal of a device from the tape zone, this message might be generated:
Error: FCIO_RESET_LINK ioctl failed.
Could not reset the loop
Workaround:
To avoid encountering the error message, manually unconfigure the unusable device (the device removed from the tape zone) at the attachment point of the device:
To Manually Unconfigure the Unusable Device
  1. Issue the cfgadm -al unusable-device-attachment-point command to list the unusable device, as described in the following procedure.
    In this example, the attachment point of the unusable device is c1.
    > cfgadm -al c1
    Ap_Id                          Type         Receptacle   Occupant
    Condition
    c1                             fc-fabric    connected    configured
    unknown
    c1::12340080e512b600           disk         connected    configured
    unknown
    c1::123400a0b82804a6           disk         connected    configured
    unusable
    c1::123410a0008beb2a           tape         connected    configured
    unknown
  2. Issue the cfgadm -c unconfigure -o unusable_SCSI_LUN unusable-device-attachment-point command to unconfigure the unusable devices on the attachment point.
    > cfgadm -c unconfigure -o unusable_SCSI_LUN c1
    Note - If a device is manually unconfigured, it must then be manually configured in order to return to the tape zone.
