Go to main content
Sun Storage 10 GbE FCoE ExpressModule Converged Network Adapter From QLogic Installation Guide For Adapter Models SG-EMFCOE2-Q-SR, SG-XEMFCOE2-Q-SR, SG-EMFCOE2-Q-TA, SG-XEMFCOE2-Q-TA, and 7101682
Exit Print View
Updated: January 2017
The Adapter Is Not Logging Into the Brocade 8000 Switch
Bug 15622146
Issue:
When configuring an Oracle Solaris 10 system with the adapter, the host-side adapter might not log into the Brocade 8000 switch unless VLAN 1002 is configured on the switch; specifically on the port to which the adapter is connected.
Workaround:
Configure the Brocade 8000 port that is connected to the host-side adapter so that the port is included in VLAN 1002. For more information, see the Brocade documentation that describes how to configure ports.
