| Skip Navigation Links | |
| Exit Print View | |
SPARC SuperCluster T4-4 Enterprise Manager 12c Component of the Oracle Optimized Solution for Enterprise Database Cloud Configuration Guide |
Setting Up the Database as a Service
Add Credentials for the Oracle Software Update Center
Add Virtualizations, Cloud, and Chargeback Plug-ins
Install the Cloud Control Agent on the SPARC SuperCluster 1.1
Installing the EM12c Agent(s) on the Oracle Solaris Zones
Add the Oracle Solaris Zones Host Targets
Create an Enterprise Manager Cloud Administrator Role
Create an Enterprise Manager Self Service User
Create Database Deployment Procedure (Single Instance)
Create a PaaS Infrastructure Zone
Establish Quotas for the Cloud Control User
Database Cloud is implemented directly onto the logical domains of the SPARC SuperCluster (Global Zone) or within Non-Global Oracle Solaris Zones that are created on the logical domains.
Much of the preparation work in setting up the hardware was done during initial system installation, compared to using a non engineered system. The only step you must perform is to enable the sudo privileges.
For a complete list of requirements for installing the Oracle Cloud Control Management Agent, refer to the Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide 12c Release 1 (12.1.0.1).
Ensure that Oracle has permission to run the required agent commands in privileged mode by adding the following to the /etc/sudoers file on the target zone.
# egrep -v "^#|^$" /etc/sudoers oracle ALL=(root) /usr/bin/id, <agent-installation-base-directory>/agentibd/*/agentdeployroot.sh
