| Skip Navigation Links | |
| Exit Print View | |
SPARC SuperCluster T4-4 Enterprise Manager 12c Component of the Oracle Optimized Solution for Enterprise Database Cloud Configuration Guide |
Setting Up the Database as a Service
Prepare the Target Oracle Solaris 11 Zones or Logical Domains
Add Credentials for the Oracle Software Update Center
Add Virtualizations, Cloud, and Chargeback Plug-ins
Install the Cloud Control Agent on the SPARC SuperCluster 1.1
Installing the EM12c Agent(s) on the Oracle Solaris Zones
Add the Oracle Solaris Zones Host Targets
Create an Enterprise Manager Cloud Administrator Role
Create an Enterprise Manager Self Service User
Create Database Deployment Procedure (Single Instance)
Create a PaaS Infrastructure Zone
Establish Quotas for the Cloud Control User
This document contains information about how to set up the Enterprise Manager Cloud Control 12c release 2 component of the Oracle Optimized Solution for Enterprise Database Cloud on the SPARC SuperCluster T4-4 from Oracle. This document is written for system administrators who have advanced experience configuring engineered systems.
Software versions required for this document are:
Enterprise Manager Cloud Control version 12.1.0.2.0
Oracle Database Plug-in 12.1.0.2.0
Note - The administrative user 'SYSMAN' is used in this guide only as a way of simplifying these instructions. In a full production environment it is assumed that enterprise manager cloud administrator accounts would be created and used for most of the steps in this guide.
This setup guide is not intended to replace the Enterprise Manager Cloud Control documentation, rather it is intended to give a worked example so as to facilitate first-time setup of Database as a service on SuperCluster
Documentation and resources for this product and related products are available on the system. Access the documentation by using a browser to view this directory on the first compute server installed in SuperCluster T4-4:
/opt/oracle/node/doc/E21659_01/index.html
Provide feedback about this documentation at:
