| Skip Navigation Links | |
| Exit Print View | |
SPARC SuperCluster T4-4 Enterprise Manager 12c Component of the Oracle Optimized Solution for Enterprise Database Cloud Configuration Guide |
Setting Up the Database as a Service
Prepare the Target Oracle Solaris 11 Zones or Logical Domains
Add Credentials for the Oracle Software Update Center
Add Virtualizations, Cloud, and Chargeback Plug-ins
Install the Cloud Control Agent on the SPARC SuperCluster 1.1
Installing the EM12c Agent(s) on the Oracle Solaris Zones
Add the Oracle Solaris Zones Host Targets
Add the Details of the RAC Cluster
Create an Enterprise Manager Cloud Administrator Role
Create an Enterprise Manager Self Service User
Create Database Deployment Procedure (Single Instance)
Create a PaaS Infrastructure Zone
This database software pool will contain the ORACLE_HOME installations that will be used to create database instances on the servers (zones) in the PaaS infrastructure zone.
The Database Pools window is displayed.
The Create Software Pool wizard is displayed.
In the example, the maximum amount of databases per host is set to 10 for demonstration purposes. In a live deployment this number is determined as part of the overall system sizing exercise.
Select the DevTestZone PaaS infrastructure zone created earlier and set the correct Oracle Solaris version.
The new database pool is available on the Database Pools window.
