| Skip Navigation Links | |
| Exit Print View | |
SPARC SuperCluster T4-4 Enterprise Manager 12c Component of the Oracle Optimized Solution for Enterprise Database Cloud Configuration Guide |
Setting Up the Database as a Service
Prepare the Target Oracle Solaris 11 Zones or Logical Domains
Add Credentials for the Oracle Software Update Center
Add Virtualizations, Cloud, and Chargeback Plug-ins
Install the Cloud Control Agent on the SPARC SuperCluster 1.1
Add the Oracle Solaris Zones Host Targets
Add the Details of the RAC Cluster
Create an Enterprise Manager Cloud Administrator Role
Create an Enterprise Manager Self Service User
Create Database Deployment Procedure (Single Instance)
Create a PaaS Infrastructure Zone
Establish Quotas for the Cloud Control User
Now you can manually deploy the Agent and Database Plug-ins to the Oracle Solaris zones on the SPARC SuperCluster. There are two parts to the agent deployment, firstly to install the EM12c Agent to the Hosts (in this case the Oracle Solaris Zones) that EM12c will use for Cloud management and the second part is to use the EM12c Guided Process to add the Agents for the Oracle RAC Clusters that run on the SuperCluster
