| Skip Navigation Links | |
| Exit Print View | |
SPARC SuperCluster T4-4 Enterprise Manager 12c Component of the Oracle Optimized Solution for Enterprise Database Cloud Configuration Guide |
Setting Up the Database as a Service
Prepare the Target Oracle Solaris 11 Zones or Logical Domains
Add Credentials for the Oracle Software Update Center
Add Virtualizations, Cloud, and Chargeback Plug-ins
Install the Cloud Control Agent on the SPARC SuperCluster 1.1
Installing the EM12c Agent(s) on the Oracle Solaris Zones
Add the Oracle Solaris Zones Host Targets
Add the Details of the RAC Cluster
Create an Enterprise Manager Cloud Administrator Role
Create an Enterprise Manager Self Service User
Create Database Deployment Procedure (Single Instance)
Establish Quotas for the Cloud Control User
The Create PaaS Infrastructure Zone wizard is displayed.
The following example uses DevTestZone as a name, indicating that databases for development and test will be in this zone. In this example, the default placement policy constrains are used, but in a development or test area you might allow starting of new database instances (placement) on Oracle Solaris zones that are more heavily used than 80%.
Click Next to continue. The Create PaaS Infrastructure Zone: Targets page is displayed.
Click on each Oracle Solaris zone you want to add as a target, then click Select.
Click the + icon to add new named credentials.
The example uses the ORACLE credential created earlier.
The example uses the EM_SSA_DEVUSER_IT role created earlier.
A message confirms that the PaaS Infrastructure Zone was successfully created. You will return to the Middleware and Database Cloud Home page.
