After you have installed your server, you have several different options for system management depending on your situation.
Managing many servers.
Your server can be managed with a wide variety of system management tools. For more information on system management tools, refer to:
http://www.oracle.com/goto/system-management
The following is an overview of some of the system management tools for multiple systems:
If you want to manage your server from a single interface, provision firmware, an operating system, or operating system updates to multiple servers, you can use the Oracle Enterprise Manager Ops Center. For more details, refer to:
If you want to monitor your enterprise servers, you can take advantage of Sun Management Center. For more details, refer to:
http://www.oracle.com/technetwork/systems/patches/sysmgmt/smc-jsp-138444.html
If you already have third-party system management tools, the servers can integrate with many third-party tools. For more details, refer to:
Managing a single server.
The following sections contain information on single server management tools.
