Go to main content
Sun Server X4-4 Installation Guide
Exit Print View
Updated: October 2015
Installing Updates
The following sections provide information about installing firmware and software updates:
Installing Firmware
Updated firmware can be installed using one of the following:
  • Oracle Enterprise Manager Ops Center – Ops Center Enterprise Controller can automatically download the latest firmware from Oracle, or firmware can be loaded manually into the Enterprise Controller. In either case, Ops Center can install the firmware onto one or more servers, blades, or blade chassis.
    For more information, go to: http://www.oracle.com/technetwork/oem/ops-center/index.html.
  • Oracle System Assistant – Oracle System Assistant can download and install the latest firmware from Oracle.
    For more information, see the Oracle X4 Series Servers Administration Guide (http://www.oracle.com/goto/x86AdminDiag/docs).
  • Oracle Hardware Management Pack – The fwupdate CLI Tool within the Oracle Hardware Management Pack can be used to update firmware within the system.
    For more information, refer to the Oracle Hardware Management Pack Documentation Library at: http://www.oracle.com/goto/ohmp/docs
  • Oracle ILOM – Oracle ILOM and BIOS firmware are the only firmware that can be updated using either the Oracle ILOM web interface or the command-line interface.
    For more information, refer to the documentation for your supported version of Oracle Lights Out Manager (ILOM) Documentation Library at: http://www.oracle.com/goto/ILOM/docs
Installing Hardware Drivers and OS Tools
Updated hardware drivers and operating system (OS)-related tools, such as Oracle Hardware Management Pack, can be installed using one of the following:
