Go to main content
Sun Server X4-4 Installation Guide
Exit Print View
Updated: October 2015
Installing the Server Into a Rack
This section describes how to place the server into a rack using the rail assembly in the rackmount kit. Perform these procedures if the rail assembly is purchased.
Note -  In this guide, the term rack means either an open rack or a closed cabinet.
Description
Links
Review safety precautions.
Review the compatibility requirements for your rack.
Install mounting brackets onto the server.
Attach the tool-less slide-rail assembly to the rack.
Install the server into the slide-rail assembly.
(Optional) Install the cable management arm for routing server cables.
Verify that the slide-rails and cable management arm are working correctly.
