Understanding the Installation
Understanding Management and Power Cabling
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Configuring the Switching Feature
Configuring the Routing Feature
Configure Static Unicast Route Entries
Configure OSPF Dynamic Routing
Check Switch Status (Oracle ILOM)
This task configures dynamic routing with the redistribution feature of RIP in SEFOS. This task also verifies the accessibility of the two hosts by learning the routes dynamically through RIP.
See Routing Feature Topology for the topology of this task.
See Configure Static Unicast Route Entries.
The basic VLAN configuration for dynamic routing is similar to the basic VLAN configuration for static routing. If the configuration information was not saved on SEFOS-1 and SEFOS-2, follow Step 1 through Step 6 in Configure Static Unicast Route Entries, then return here.
SEFOS-1# configure terminal SEFOS-1(config)# router rip SEFOS-1(config-router)# neighbor 20.0.0.200 SEFOS-1(config-router)# network 20.0.0.201 SEFOS-1(config-router)# network 10.0.0.201 SEFOS-1(config-router)# redistribute all SEFOS-1(config-router)# end
SEFOS-2# configure terminal SEFOS-2(config)# router rip SEFOS-2(config-router)# neighbor 20.0.0.201 SEFOS-2(config-router)# network 20.0.0.200 SEFOS-2(config-router)# network 40.0.0.200 SEFOS-2(config-router)# redistribute all SEFOS-2(config-router)# end
If SEFOS-2 is a third-party switch, verify that the RIP is enabled on SEFOS-2 and that related configurations are applied accordingly.
SEFOS-1# show ip rip database Vrf default 10.0.0.0/8 [1] auto-summary 10.0.0.0/24 [1] directly connected, vlan10 20.0.0.0/8 [1] auto-summary 20.0.0.0/24 [1] directly connected, vlan20 40.0.0.0/8 [2] auto-summary 40.0.0.0/8 [2] via 20.0.0.200, vlan20
SEFOS-2# show ip rip database Vrf default 10.0.0.0/8 [2] auto-summary 10.0.0.0/8 [2] via 20.0.0.201, vlan20 20.0.0.0/8 [1] auto-summary 20.0.0.0/24 [1] directly connected, vlan20 40.0.0.0/8 [1] auto-summary 40.0.0.0/24 [1] directly connected, vlan40
# ping 10.0.0.201
# ping 10.0.0.169
# ping 40.0.0.110
You can test the basic routing features of SEFOS now that SEFOS is able to dynamically learn the routing entries using the redistribution feature of RIP.
