This chapter provides the software procedures for administering the Oracle Solaris Cluster interconnects and public networks.
Administering the cluster interconnects and public networks consists of both hardware and software procedures. Typically, you configure the cluster interconnects and public networks, including Internet Protocol (IP) Network Multipathing groups, when you initially install and configure the cluster. Multipathing is installed automatically with the Oracle Solaris 11 OS, and you must enable it to use it. If you later need to alter a cluster interconnect network configuration, you can use the software procedures in this chapter. For information about configuring IP Network Multipathing groups in a cluster, see the section Administering the Public Network.
This chapter provides information and procedures for the following topics.
For a high-level description of the related procedures in this chapter, see Table 7–1 and Table 7–3.
Refer to the Oracle Solaris Cluster Concepts Guide for background and overview information about the cluster interconnects and public networks.
