Installing Ethernet or InfiniBand
Cluster Interconnect Hardware
The following table lists procedures for installing Ethernet
or InfiniBand cluster interconnect hardware. Perform the procedures
in the order that they are listed. This section contains the procedure
for installing cluster hardware during an initial installation of
a cluster, before you install Oracle Solaris Cluster software.
Table 3-1 Installing
Ethernet Cluster Interconnect Hardware | |
Install the transport adapters.
| The documentation that shipped with your nodes and host adapters
Install the transport cables.
If your cluster contains more than two nodes, install a transport junction (switch).
