oracle home
Oracle
Solaris Cluster 4.2 Hardware Administration Manual
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Oracle Solaris Cluster 4.2
Oracle
Solaris Cluster 4.2 ...
Verifying Oracle Solaris Cluster Hardware ...
Testing Cluster Interconnect Redundancy
Updated: July 2014, E39726–01
Oracle
Document Information
Using This Documentation
Product Documentation Library
Access to Oracle Support
Documentation Accessibility
Feedback
Chapter 1 Introduction to Oracle Solaris Cluster Hardware
Installing Oracle Solaris Cluster Hardware
Supported Configurations
Maintaining Oracle Solaris Cluster Hardware
Powering Oracle Solaris Cluster Hardware On and Off
Dynamic Reconfiguration Operations for Oracle Solaris Cluster Nodes
Dynamic Reconfiguration Operations in a Cluster With Dynamic Reconfiguration-Enabled Servers
Local and Multihost Disks in an Oracle Solaris Cluster Environment
Removable Media in an Oracle Solaris Cluster Environment
SAN Solutions in an Oracle Solaris Cluster Environment
Hardware Restrictions
Chapter 2 Installing and Configuring the Terminal Concentrator
Installing the Terminal Concentrator
How to Install the Terminal Concentrator in a Cabinet
How to Connect the Terminal Concentrator
How to Configure the Terminal Concentrator
How to Set Terminal Concentrator Port Parameters
How to Correct a Port Configuration Access Error
How to Establish a Default Route for the Terminal Concentrator
Using the Terminal Concentrator
How to Connect to a Node's Console Through the Terminal Concentrator
How to Reset a Terminal Concentrator Port
Chapter 3 Installing Cluster Interconnect Hardware and Configuring VLANs
Interconnect Requirements and Restrictions
Cluster Interconnect and Routing
Cluster Interconnect Speed Requirements
Ethernet Switch Configuration When in the Cluster Interconnect
Requirements When Using Jumbo Frames
Requirements and Restrictions When Using Sun InfiniBand from Oracle in the Cluster Interconnect
Requirements for Socket Direct Protocol Over an Oracle Solaris Cluster Interconnect
Installing Ethernet or InfiniBand Cluster Interconnect Hardware
How to Install Ethernet or InfiniBand Transport Cables and Transport Junctions
Configuring VLANs as Private Interconnect Networks
Chapter 4 Maintaining Cluster Interconnect Hardware
Maintaining Interconnect Hardware in a Running Cluster
How to Add an Interconnect Component
How to Replace an Interconnect Component
How to Remove an Interconnect Component
How to Upgrade Transport Adapter Firmware
Chapter 5 Installing and Maintaining Public Network Hardware
Public Network Hardware: Requirements When Using Jumbo Frames
Installing Public Network Hardware
Installing Public Network Hardware: Where to Go From Here
Maintaining Public Network Hardware in a Running Cluster
Adding Public Network Adapters
Adding Public Network Adapters: Where to Go From Here
Replacing Public Network Adapters
Replacing Public Network Adapters: Where to Go From Here
Removing Public Network Adapters
Chapter 6 Maintaining Platform Hardware
Mirroring Internal Disks on Servers that Use Internal Hardware Disk Mirroring or Integrated Mirroring
How to Configure Internal Disk Mirroring After the Cluster Is Established
How to Remove an Internal Disk Mirror
Configuring Cluster Nodes With a Single, Dual-Port HBA
Risks and Trade-offs When Using One Dual-Port HBA
Supported Configurations When Using a Single, Dual-Port HBA
Cluster Configuration When Using Solaris Volume Manager and a Single Dual-Port HBA
Configuration Requirements
Expected Failure Behavior with Solaris Volume Manager
Failure Recovery with Solaris Volume Manager
Cluster Configuration When Using Solaris Volume Manager for Oracle Solaris Cluster and a Single Dual-Port HBA
Expected Failure Behavior with Solaris Volume Manager for Oracle Solaris Cluster
Failure Recovery with Solaris Volume Manager for Oracle Solaris Cluster
Kernel Cage Dynamic Reconfiguration Recovery
Preparing the Cluster for Kernel Cage Dynamic Reconfiguration
How to Recover From an Interrupted Kernel Cage Dynamic Reconfiguration Operation
Chapter 7 Campus Clustering With Oracle Solaris Cluster Software
Requirements for Designing a Campus Cluster
Selecting Networking Technologies
Connecting to Storage
Shared Data Storage
Complying With Quorum Device Requirements
Replicating Solaris Volume Manager Disksets
Guidelines for Designing a Campus Cluster
Determining the Number of Rooms in Your Cluster
Three-Room Campus Cluster Examples
Deciding How to Use Quorum Devices
Quorum in Clusters With Four Rooms or More
Quorum in Three-Room Configurations
Quorum in Two-Room Configurations
Determining Campus Cluster Connection Technologies
Cluster Interconnect Technologies
Storage Area Network Technologies
Installing and Configuring Interconnect, Storage, and Fibre Channel Hardware
Calculating Buffer Credits
Additional Campus Cluster Configuration Examples
Chapter 8 Verifying Oracle Solaris Cluster Hardware Redundancy
Testing Node Redundancy
How to Test Device Group Redundancy Using Resource Group Failover
How to Test Cluster Interconnects
Testing Public Network Redundancy
How to Test Public Network Redundancy
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index J
Index K
Index L
Index M
Index N
Index O
Index P
Index Q
Index R
Index S
Index T
Index U
Index V
Language:
English
This section provides the procedure for testing cluster interconnect redundancy.
Previous
Next
