These sections describe how to service and install PCIe cards. Refer to your PCIe card documentation for complete software and cabling information about your card.
Caution - These procedures require that you handle components that are sensitive to electrostatic discharge. This sensitivity can cause the components to fail. To avoid damage, ensure that you follow antistatic practices as described in Take Antistatic Measures. |
Caution - Ensure that all power is removed from the storage server before removing or installing PCIe cards. You must disconnect all power cables from the system before performing these procedures. |
This section covers the following topics:
