Viewing Component Information
Note -
You can use
get commands to view
component information. For a description of valid MIB objects for
this procedure, see the table following this procedure.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For
example, type:
ssh
username@snmp_manager_ip_address
Password:
password
To view the firmware revision, type:
% snmpget SNMP_agent entPhysicalFirmwareRev.1
The following table describes the Component Information SNMP MIB
objects.
entPhysical
Name
The textual name of the physical entity.
Size: 0 to 255
String
Zero- length string
entPhysical
Descr
A textual description of the physical entity.
Size: 0 to 255
String
None
entPhysical
ContainedIn
The value of entPhysicalIndex for the physical entity that
contains this physical entity. A
value of 0 indicates this physical entity is not contained
in any other physical entity.
Range: 0 to 2147483647
Integer
None
entPhysical
Class
An indication of the general hardware type of the physical
entity.
other(1),
unknown(2),
chassis(3),
backplane(4),
container(5),
powerSupply(6),
fan(7),
sensor(8),
module(9),
port(10),
stack(11)
Integer
None
entPhysical
FirmwareRev
The vendor-specific firmware revision string for the
physical entity.
Size: 0 to 255
String
Zero- length string
