Viewing the Oracle ILOM Event Log
Note -
You can use the
get command to view the Oracle
ILOM event log and the
set command to configure
the event log. For a description of valid MIB objects for this procedure, see
the table following this procedure.
Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For
example, type:
ssh
username@snmp_manager_ip_address
Password: password
To view the event log type for an event log with a record ID of 2,
type:
% snmpget SNMP_agent ilomSystemLogTable
The following table describes the Oracle ILOM Event Logs SNMP MIB
objects.
ilomSystemLogRecordID
Unsigned32
The record number uniquely identifying the ilomSystem log
entry.
ilomSystemLogTimestamp
DateAndTime
The date and time that the ilomSystem log entry was
recorded.
ilomSystemLogSubsystem
SnmpAdminString
The subsystem the event pertains to.
ilomSystemLogComponent
SnmpAdminString
The component the event pertains to.
ilomSystemLogDescription
OCTET STRING
A textual description of the event.
