Rate Schedule - Sub Rates
Select Sub Rates page to define any subsidiary rate schedules associated with the current (primary) rate schedule.
and navigate to theSub Rates are only allowed on Primary rate schedules. See Use Sub Rate Schedules to Encapsulate Common Rate Components for more information about subsidiary rate schedules.
Description of Page
Use the Sub Rate Schedule collection to define the subsidiary rate schedules linked to the current rate schedule.
The Sequence is important when you have multiple sub rates linked to the primary rate, as it defines the order in which the sub rates will be calculated.
Where Used
At billing time, if there are sub rate schedules linked to the service agreement's primary rate schedule, rate components defined in the sub rate schedules are used to calculate charges. Bill segments contain separate bill calculation details for each primary rate schedule and sub rate schedule used in its calculation.
