Rate Component Cross Reference Information
All information related to a rate component, including general ledger information, characteristics and eligibility rules, will be copied.
Special logic exists for merged rate components that reference other rate components. This includes the cross-reference collection and the eligibility criteria.
This logic is difficult to explain succinctly, so we'll use an example. Imagine that the Merge From rate components look as follows:
![The figure illustrates how data appears in the Rate Version Merge screen.](../images/BP14Rates030.jpg)
The Rate Component - Cross Reference tab for the merge from rate version shows the following cross-reference information for sequence 210:
![The figure illustrates how the data appears in the Apply This Rate Component To section.](../images/BP14Rates032.jpg)
Assume that only rate components 10, 20 and 210 are copied to the new rate version and assume that the Original rate version already contains a rate component with sequence number 10 that is moved to the second position.
![The figure illustrates how the data appears when you copy and move the rate components from one rate version to another.](../images/BP14Rates034.jpg)
After saving, the second service quantity rate component is renumbered and the State tax rate component will reflect the renumbering in the cross-reference and will not include the rate components that were not copied.
Here is the view on the merge page after saving:
![The figure indicates that the rate components are automatically renumbered when you save the data in the Rate Version Merge screen.](../images/BP14Rates036.jpg)
If you navigate to the Rate Component - Cross Reference tab for the original rate version for sequence 40- State tax, it will look as follows:
![The figure illustrates how the data appears in the Apply This Rate Component To section.](../images/BP14Rates038.jpg)
If any rate component refers to another rate component in the eligibility criteria, the sequence number of the eligibility criteria is also adjusted accordingly.
