Skip Navigation Links | |
Exit Print View | |
man pages section 9: DDI and DKI Kernel Functions Oracle Solaris 10 8/11 Information Library |
csx_AccessConfigurationRegister(9F)
csx_Parse_CISTPL_BYTEORDER(9F)
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
csx_Parse_CISTPL_DEVICEGEO(9F)
csx_Parse_CISTPL_DEVICEGEO_A(9F)
csx_Parse_CISTPL_DEVICE_OA(9F)
csx_Parse_CISTPL_DEVICE_OC(9F)
csx_Parse_CISTPL_LINKTARGET(9F)
csx_Parse_CISTPL_LONGLINK_A(9F)
csx_Parse_CISTPL_LONGLINK_C(9F)
csx_Parse_CISTPL_LONGLINK_MFC(9F)
ddi_get_soft_iblock_cookie(9F)
ddi_intr_get_supported_types(9F)
ddi_prop_lookup_byte_array(9F)
ddi_prop_lookup_int64_array(9F)
ddi_prop_lookup_string_array(9F)
ddi_prop_update_byte_array(9F)
ddi_prop_update_int64_array(9F)
ddi_prop_update_string_array(9F)
ldi_prop_lookup_byte_array(9F)
ldi_prop_lookup_int64_array(9F)
ldi_prop_lookup_string_array(9F)
mac_prop_info_set_default_link_flowctrl(9F)
mac_prop_info_set_default_str(9F)
mac_prop_info_set_default_uint8(9F)
mac_prop_info_set_range_uint32(9F)
net_event_notify_unregister(9F)
net_instance_notify_register(9F)
net_instance_notify_unregister(9F)
net_instance_protocol_unregister(9F)
net_protocol_notify_register(9F)
nvlist_lookup_boolean_array(9F)
nvlist_lookup_boolean_value(9F)
nvlist_lookup_nvlist_array(9F)
nvlist_lookup_string_array(9F)
nvlist_lookup_uint16_array(9F)
nvlist_lookup_uint32_array(9F)
nvlist_lookup_uint64_array(9F)
nvpair_value_boolean_array(9F)
scsi_get_device_type_scsi_options(9F)
scsi_sense_cmdspecific_uint64(9F)
usb_get_current_frame_number(9F)
usb_get_max_pkts_per_isoc_request(9F)
usb_pipe_get_max_bulk_transfer_size(9F)
usb_pipe_stop_intr_polling(9F)
usb_pipe_stop_isoc_polling(9F)
- zero fill the device
#include <sys/ddi.h> #include <sys/sunddi.h> int ddi_device_zero(ddi_acc_handle_t handle, caddr_t dev_addr, size_t bytecount, ssize_t dev_advcnt, uint_t dev_datasz);
Solaris DDI specific (Solaris DDI).
The data access handle returned from setup calls, such as ddi_regs_map_setup(9F).
Beginning of the device address.
Number of bytes to zero.
Number of dev_datasz units to advance on every access.
The size of each data word. Possible values are defined as:
1 byte data size
2 bytes data size
4 bytes data size
8 bytes data size
ddi_device_zero() function fills the given, bytecount, number of byte of zeroes to the device register or memory.
The dev_advcnt argument determines the value of the device address, dev_addr, on each access. A value of 0 will use the same device address, dev_addr, on every access. A positive value increments the device address in the next access while a negative value decrements the address. The device address is incremented and decremented in dev_datasz units.
The dev_datasz argument determines the size of data word on each access.
ddi_device_zero() returns:
Successfully zeroed the data.
The byte count is not a multiple of dev_datasz.
ddi_device_zero() can be called from user, kernel, or interrupt context.
