Skip Navigation Links | |
Exit Print View | |
man pages section 9: DDI and DKI Kernel Functions Oracle Solaris 10 8/11 Information Library |
csx_AccessConfigurationRegister(9F)
csx_Parse_CISTPL_BYTEORDER(9F)
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
csx_Parse_CISTPL_DEVICEGEO(9F)
csx_Parse_CISTPL_DEVICEGEO_A(9F)
csx_Parse_CISTPL_DEVICE_OA(9F)
csx_Parse_CISTPL_DEVICE_OC(9F)
csx_Parse_CISTPL_LINKTARGET(9F)
csx_Parse_CISTPL_LONGLINK_A(9F)
csx_Parse_CISTPL_LONGLINK_C(9F)
csx_Parse_CISTPL_LONGLINK_MFC(9F)
ddi_get_soft_iblock_cookie(9F)
ddi_intr_get_supported_types(9F)
ddi_prop_lookup_byte_array(9F)
ddi_prop_lookup_int64_array(9F)
ddi_prop_lookup_string_array(9F)
ddi_prop_update_byte_array(9F)
ddi_prop_update_int64_array(9F)
ddi_prop_update_string_array(9F)
ldi_prop_lookup_byte_array(9F)
ldi_prop_lookup_int64_array(9F)
ldi_prop_lookup_string_array(9F)
mac_prop_info_set_default_link_flowctrl(9F)
mac_prop_info_set_default_str(9F)
mac_prop_info_set_default_uint8(9F)
mac_prop_info_set_range_uint32(9F)
net_event_notify_unregister(9F)
net_instance_notify_register(9F)
net_instance_notify_unregister(9F)
net_instance_protocol_unregister(9F)
net_protocol_notify_register(9F)
nvlist_lookup_boolean_array(9F)
nvlist_lookup_boolean_value(9F)
nvlist_lookup_nvlist_array(9F)
nvlist_lookup_string_array(9F)
nvlist_lookup_uint16_array(9F)
nvlist_lookup_uint32_array(9F)
nvlist_lookup_uint64_array(9F)
nvpair_value_boolean_array(9F)
scsi_get_device_type_scsi_options(9F)
scsi_sense_cmdspecific_uint64(9F)
usb_get_current_frame_number(9F)
usb_get_max_pkts_per_isoc_request(9F)
usb_pipe_get_max_bulk_transfer_size(9F)
usb_pipe_stop_intr_polling(9F)
usb_pipe_stop_isoc_polling(9F)
- Create power management components for USB devices
#include <sys/usb/usba.h> int usb_create_pm_components(dev_info_t *dip, uint_t *pwrstates);
Solaris DDI specific (Solaris DDI)
Pointer to the device's dev_info structure.
Address into which a mask which lists power states capable by device is returned. This is a bitmask containing zero or more of the following values:
Corresponds to USB_DEV_OS_PWR_3 or full power.
Corresponds to USB_DEV_OS_PWR_2.
Corresponds to USB_DEV_OS_PWR_1.
Corresponds to USB_DEV_OS_PWR_0 or no power.
The usb_create_pm_components() function creates pm component properties that assume the standard USB D0-D3 powerlevels (USB_DEV_PWR_D0 - USB_DEV_PWR_D3). See the device's relevant USB descriptor to determine the device's power management capabilities and account for bus-powered devices. The usb_create_pm_components() function also updates the pm-components property in the device's dev_info structure.
Note that these USB power levels are inverse of OS power levels. For example, USB_DEV_OS_PWR_0 and USB_DEV_PWR_D3 are equivalent levels corresponding to powered-down.
Power management facilities in device are recognized by system.
An error occurred.
May be called from user or kernel context.
uint_t *pwrstates; /* Hook into device's power management. Enable remote wakeup. */ if (usb_create_pm_components(dip, pwrstates) == USB_SUCCESS) { usb_handle_remote_wakeup(dip,USB_REMOTE_WAKEUP_ENABLE); }
attributes(5), usb_clr_feature(9F), usb_register_hotplug_cbs(9F), usb_get_cfg(9F), usb_get_dev_data(9F), usb_handle_remote_wakeup(9F), pm_idle_component(9F), pm_busy_component(9F), pm_raise_power(9F), pm_lower_power(9F), usb_cfg_descr(9S)
