Skip Navigation Links
Exit Print View
Netra Blade X3-2B (formerly Sun Netra X6270 M3 Server Module) HTML Document Collection
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
About Blade Features and Components
Blade Features
Blade Front Panel Features
Blade Rear Panel Features
UEFI BIOS
Specifications
Installing the Blade
Installation Overview
Preparing to Install the Blade
Shipping Inventory List
ESD and Safety Precautions
Additional Components
Prepare the Chassis
Install Your Blade
Cabling the Blade
Attach the 3-Cable Dongle to the Blade
Attach a VGA Monitor to the Dongle Video Connector
Attach a Keyboard and Mouse to the Dongle or Blade
Attach a Serial Device to the Dongle
Cable the CMM NET MGT Port
Connecting to Oracle ILOM
Oracle ILOM Overview
Determining the Oracle ILOM SP IP Address
Logging In to Blade SP Oracle ILOM
Accessing the Blade Console Through Oracle ILOM
Setting Up Software and Firmware
Accessing Oracle System Assistant
Set Up Software and Firmware (Oracle System Assistant)
Setting Up an Operating System and Drivers
Preparing the Storage Drives to Install an Operating System
Supported Host Bus Adapters
Prepare the Storage Drives (Oracle System Assistant)
Make a Virtual Drive Bootable (LSI WebBIOS Utility)
Configuring the Preinstalled Oracle Solaris OS
Oracle Solaris OS Documentation
Configuration Worksheet
Configure Preinstalled Oracle Solaris 11
Configuring Preinstalled Oracle VM Software
Oracle VM Server Configuration Worksheet
Configure the Preinstalled Oracle VM Server
Updating Oracle VM Software
Getting Started With Oracle VM
Troubleshoot Installation Issues
Powering Off the Blade for Graceful Shutdown
Powering Off the Blade for Immediate Shutdown
Resetting the Blade
Identifying Blade Faults
Troubleshooting Blade Power States
Technical Support Information Worksheet
Locating the System Serial Number
Oracle Solaris OS Installation and Setup
About Oracle Solaris OS Installation
Oracle Solaris Installation Task Table
Supported OS Versions and Latest Information
OS Installation Options
Preparing to Install the OS
Obtaining Oracle Solaris Documentation
Setting Up the Installation Session
Setting Up the BIOS
Installing the Oracle Solaris OS
Install Supported Versions of the Oracle Solaris OS
Identify Logical and Physical Network Interface Names
Installing Server System Tools and Accessing Drivers
Oracle VM OS Installation and Setup
About Oracle VM Software Installation
Oracle VM Installation Task Table
Oracle VM Overview
Oracle VM Installation Options
Preparing for Oracle VM Server Installation
Preparing the Installation Environment
Creating a Virtual Disk and Setting the Boot Disk
Verify BIOS Optimal Defaults
Installing Oracle VM Server
Install Oracle VM Server (Oracle System Assistant)
Installing Oracle VM Server (Manually)
Completing the Oracle VM Installation
Install Server System Tools
Update the Oracle VM Drivers
Creating and Managing Oracle VM Resources
Linux OS Installation and Setup
About Linux Installation
Downloading Installation Media Kits
Setting Up the Installation Method
Setting Up the BIOS
Installing the Operating System
Identifying Logical and Physical Network Interface Names for Linux OS Configuration
Identify Logical and Physical Network Interface Names While Installing Oracle Linux or RHEL
Identify Logical and Physical Network Interface Names While Installing SLES
Install a Linux OS (Oracle System Assistant)
Installing a Linux OS (Manually)
Install OEL Manually
Install SLES Manually
Install RHEL Manually
Installing Server System Tools and Updating Drivers
Update System Drivers
Updating a Linux OS to a New Version
Update the Linux Operating System Version
Update the SLES Operating System Version
Update the RHEL Operating System Version
Windows OS Installation and Setup
About Windows OS Installation
Setting Up the BIOS
Installing the Windows OS
Install Windows (Oracle System Assistant)
Install Windows Server 2008 R2 Manually
Install Windows Server 2008 (PXE)
VMware ESXi Installation and Setup
About VMware ESXi 5 Installation
Installation Task Map
VMware ESXi 5 and Blade Documentation
Software Installation Options
Single-Server Interactive Installation Methods
Preparing for ESXi 5 Installation
Set Up for Local Installation
Set Up for Remote Installation
Gather Required Information
Enable UEFI BIOS
Installing VMware ESXi 5
Install VMware ESXi 5 Using Local or Remote Interactive Installation
Update VMware ESXi 5
Install VMware ESXi 5 Drivers
Administration
Planning the System Management Environment
Choosing Tools for Single System Management
Choosing Tools for Multiple System Management
System Management Tools Overview
Common System Management Tasks
Common System Administrative Tasks
Evaluating the Server Environment
Accessing System Management Tools
Accessing Oracle ILOM
Accessing Oracle Hardware Management Pack
Setting Up the Blade With Oracle System Assistant
Overview of Oracle System Assistant
Using the Help and Exit Buttons
Using Oracle System Assistant for Server Configuration
Oracle System Assistant Administrative Tasks
Managing a Server Using Oracle System Assistant
Configure the Server Using Oracle System Assistant
View System Overview
View System Inventory
Configure Network Settings
Get Updates for a New Platform Software Release
Update Firmware
Configure Hardware for RAID
Configure Hardware for Oracle ILOM SP
Set Preferences to Disable Oracle System Assistant
Set Preferences for Keyboard Language
Perform Advanced Tasks to Access Oracle System Assistant Shell
Perform Advanced Tasks to Check Media Integrity
Maintaining Oracle System Assistant
Troubleshooting Oracle System Assistant
Mounting the Oracle System Assistant USB Flash Drive
Set Up Software and Firmware (OSA)
Set Up Software and Firmware (Oracle ILOM)
Set Up Software and Firmware (Oracle Hardware Management Pack)
Managing Server Policies Using Oracle ILOM
Oracle ILOM Features
Oracle ILOM Features for x86 Sun Servers
Sideband Management
Service Processor Power-On Policies
Power Management Policies Supported
Diagnostics Using Pc-Check and NMI
Control Next Boot Device
FRU TLI Auto-Update
Switch Serial Port Output to Host Management Console
Back Up and Restore BIOS Configuration
Administer Open Problems
Clear Blade Faults
Configure Management Policies Using Oracle ILOM (Web)
Configure Management Policies Using Oracle ILOM (CLI)
Configuring RAID
Supported HBA REMs
RAID Considerations
Creating a RAID Volume
Setting Up the Blade With BIOS Setup Utility
Access BIOS Setup Utility Menus
Navigate BIOS Setup Utility Menus
BIOS Key Mappings
BIOS Setup Utility Menu Overview
Selecting Legacy and UEFI BIOS
Configuring the UEFI BIOS Boot Mode
Supported Boot Modes
UEFI BIOS Advantages
Configuration Utilities for Add-In Cards
Select UEFI or Legacy BIOS Boot Mode
Common BIOS Setup Utility Tasks
Verify BIOS Factory Default Settings
Select the Boot Device
Configure TPM Support
Configure SP Network Settings
Legacy BIOS Option ROM Allocation Considerations
Configure Option ROM Settings
Modify Device Configuration
Allocating I/O Resources
Configure iSCSI Virtual Drives
Exit BIOS Setup Utility
BIOS Setup Utility Screen Reference
BIOS Main Menu Selections
BIOS Advanced Menu Selections
BIOS IO Menu Selections
BIOS Boot Menu Selections
BIOS UEFI Driver Control Menu Selections
BIOS Save & Exit Menu Selections
BIOS LSI MegaRAID Configuration Utility Screen Reference
Accessing BIOS LSI MegaRAID Configuration Utility Controller Management Menus
BIOS LSI MegaRAID Configuration Utility Controller Management Selections
BIOS LSI MegaRAID Configuration Utility Drive Management Menu Selections
BIOS LSI MegaRAID Configuration Utility Virtual Drive Management Menu Selections
BIOS LSI MegaRAID Configuration Utility Enclosure Management Menu Selections
Identifying Hardware Components and SNMP Messages
Identifying System Hardware Components
Table Legend
System Board Components (Sensors)
Sensors
Field Replaceable Units (FRUs)
SNMP and PET Traps
Service
About the Netra Blade X3-2B
Product Description
Front Panel LEDs
Rear Panel Features
Supported Chassis
About Oracle ILOM
About the Chassis Monitoring Module (CMM)
Replaceable Blade Components
Preparing the Blade for Service
Obtaining the Serial Number
Performing ESD and Antistatic Prevention Measures
Using the Locate LED to Identify the Blade
Removing the Blade from the Chassis
Removing the Blade Top Cover
Removing or Inserting Blade Filler Panels
Removing or Inserting Component Filler Panels
Connecting the Multi-port Cable
Servicing Blade Components
Servicing a Storage Drive
Servicing DIMMs
Servicing the System Battery
Servicing USB Flash Drives
Servicing a Fabric Expansion Module
Servicing a RAID Expansion Module
Servicing a Processor and Heat Sink Assembly
Servicing the Blade and Motherboard Assembly
Returning Blade to Operation
Install the Blade Top Cover
Install the Blade in the Chassis
Powering On the Blade
Power On from Oracle ILOM SP (CLI)
Power On From Oracle ILOM SP (Web)
Troubleshooting the Blade
Diagnosing Hardware Faults
Using LED Indicators
Using the DIMM and Processor Test Circuit
Using Diagnostic Tools
Troubleshooting Power States
Firmware and Software Troubleshooting
BIOS POST Checkpoints
About POST Code Checkpoint Memory Testing
Viewing POST Code Checkpoints
Configure Boot Settings
POST Code Checkpoint Reference
Index
While configuring an operating system for a networked server, you might need to provide the logical name (assigned by the OS) and the physical name (MAC address) of each network interface.
This section explains how to obtain the needed logical information in these situations. It provides the following topics.
