man pages section 3: Basic Library Functions
Exit Print View
Updated: July 2014
atomic_and_16_nv(3C)
Name
atomic_and, atomic_and_8, atomic_and_uchar, atomic_and_16, atomic_and_ushort, atomic_and_32, atomic_and_uint , atomic_and_ulong, atomic_and_64, atomic_and_8_nv, atomic_and_uchar_nv, atomic_and_16_nv, atomic_and_ushort_nv, atomic_and_32_nv, atomic_and_uint_nv, atomic_and_ulong_nv, atomic_and_64_nv - atomic AND operations
Synopsis
#include <atomic.h>
void atomic_and_8(volatile uint8_t *target, uint8_t bits);
void atomic_and_uchar(volatile uchar_t *target, uchar_t bits);
void atomic_and_16(volatile uint16_t *target, uint16_t bits);
void atomic_and_ushort(volatile ushort_t *target, ushort_t bits);
void atomic_and_32(volatile uint32_t *target, uint32_t bits);
void atomic_and_uint(volatile uint_t *target, uint_t bits);
void atomic_and_ulong(volatile ulong_t *target, ulong_t bits);
void atomic_and_64(volatile uint64_t *target, uint64_t bits);
uint8_t atomic_and_8_nv(volatile uint8_t *target, uint8_t bits);
uchar_t atomic_and_uchar_nv(volatile uchar_t *target, uchar_t bits);
uint16_t atomic_and_16_nv(volatile uint16_t *target, uint16_t bits);
ushort_t atomic_and_ushort_nv(volatile ushort_t *target, ushort_t bits);
uint32_t atomic_and_32_nv(volatile uint32_t *target, uint32_t bits);
uint_t atomic_and_uint_nv(volatile uint_t *target, uint_t bits);
ulong_t atomic_and_ulong_nv(volatile ulong_t *target, ulong_t bits);
uint64_t atomic_and_64_nv(volatile uint64_t *target, uint64_t bits);
Description
These functions enable the bitwise AND of bits to the value stored in target to occur in an atomic manner.
Return Values
The *_nv() variants of these functions return the new value of target.
Errors
No errors are defined.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
atomic_add(3C), atomic_bits(3C), atomic_cas(3C), atomic_dec(3C), atomic_inc(3C), atomic_or(3C), atomic_swap(3C), membar_ops(3C), attributes(5), atomic_ops(9F)
Notes
The *_nv() variants are substantially more expensive on some platforms than the versions that do not return values. Do not use them unless you need to know the new value atomically.
