man pages section 3: Basic Library Functions
Exit Print View
Updated: July 2014
double_to_decimal(3C)
Name
floating_to_decimal, single_to_decimal, double_to_decimal, extended_to_decimal, quadruple_to_decimal - convert floating-point value to decimal record
Synopsis
#include <floatingpoint.h>
void single_to_decimal(single *px, decimal_mode *pm,
     decimal_record *pd, fp_exception_field_type *ps);
void double_to_decimal(double *px, decimal_mode *pm,
void extended_to_decimal(extended *px, decimal_mode *pm,
void quadruple_to_decimal(quadruple *px, decimal_mode *pm,
Description
The floating_to_decimal functions convert the floating-point value at *px into a decimal record at *pd, observing the modes specified in *pm and setting exceptions in *ps. If there are no IEEE exceptions, *ps will be zero.
If *px is zero, infinity, or NaN, then only pdsign and pdfpclass are set. Otherwise pdexponent and pdds are also set so that
(sig)*(pd->ds)*10**(pd->exponent)
is a correctly rounded approximation to *px, where sig is +1 or −1, depending upon whether pdsign is 0 or −1. pdds has at least one and no more than DECIMAL_STRING_LENGTH–1 significant digits because one character is used to terminate the string with a null.
pdds is correctly rounded according to the IEEE rounding modes in pmrd. *ps has fp_inexact set if the result was inexact, and has fp_overflow set if the string result does not fit in pdds because of the limitation DECIMAL_STRING_LENGTH.
If pmdf == floating_form, then pdds always contains pmndigits significant digits. Thus if *px == 12.34 and pmndigits == 8, then pdds will contain 12340000 and pdexponent will contain −6.
If pmdf == fixed_form and pmndigits >= 0, then the decimal value is rounded at pmndigits digits to the right of the decimal point. For example, if *px == 12.34 and pmndigits == 1, then pdds will contain 123 and pd exponent will be set to −1.
If pmdf == fixed_form and pmndigits< 0, then the decimal value is rounded at −pmndigits digits to the left of the decimal point, and pdds is padded with trailing zeros up to the decimal point. For example, if *px == 12.34 and pmn digits == −1, then pdds will contain 10 and pdexponent will be set to 0.
When pmdf == fixed_form and the value to be converted is large enough that the resulting string would contain more than DECIMAL_STRING_LENGTH−1 digits, then the string placed in pdds is limited to exactly DECIMAL_STRING_LENGTH-1 digits (by moving the place at which the value is rounded further left if need be), pdexponent is adjusted accordingly and the overflow flag is set in *ps.
pd->more is not used.
The econvert(3C), fconvert(3C), gconvert(3C), printf(3C), and sprintf(3C) functions all use double_to_decimal().
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
MT-Level
MT-Safe
See Also
econvert(3C), fconvert(3C), gconvert(3C), printf(3C), sprintf(3C), attributes(5)
