Skip Navigation Links
Exit Print View
man pages section 3: Basic Library Functions
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
__fbufsize(3C)
__flbf(3C)
__fpending(3C)
__fpurge(3C)
__freadable(3C)
__freading(3C)
__fsetlocking(3C)
__fwritable(3C)
__fwriting(3C)
_edata(3C)
_end(3C)
_etext(3C)
_exithandle(3C)
_flushlbf(3C)
_longjmp(3C)
_setjmp(3C)
_stack_grow(3C)
_tolower(3C)
_toupper(3C)
a64l(3C)
abort(3C)
abs(3C)
addrtosymstr(3C)
addsev(3C)
addseverity(3C)
aio_cancel(3C)
aio_error(3C)
aio_fsync(3C)
aio_read(3C)
aio_return(3C)
aio_suspend(3C)
aio_waitn(3C)
aio_write(3C)
aiocancel(3C)
aioread(3C)
aiowait(3C)
aiowrite(3C)
alloca(3C)
alphasort(3C)
ascftime(3C)
asctime(3C)
asctime_r(3C)
asprintf(3C)
assert(3C)
atexit(3C)
atof(3C)
atoi(3C)
atol(3C)
atoll(3C)
atomic_add(3C)
atomic_add_16(3C)
atomic_add_16_nv(3C)
atomic_add_32(3C)
atomic_add_32_nv(3C)
atomic_add_64(3C)
atomic_add_64_nv(3C)
atomic_add_8(3C)
atomic_add_8_nv(3C)
atomic_add_char(3C)
atomic_add_char_nv(3C)
atomic_add_int(3C)
atomic_add_int_nv(3C)
atomic_add_long(3C)
atomic_add_long_nv(3C)
atomic_add_ptr(3C)
atomic_add_ptr_nv(3C)
atomic_add_short(3C)
atomic_add_short_nv(3C)
atomic_and(3C)
atomic_and_16(3C)
atomic_and_16_nv(3C)
atomic_and_32(3C)
atomic_and_32_nv(3C)
atomic_and_64(3C)
atomic_and_64_nv(3C)
atomic_and_8(3C)
atomic_and_8_nv(3C)
atomic_and_uchar(3C)
atomic_and_uchar_nv(3C)
atomic_and_uint(3C)
atomic_and_uint_nv(3C)
atomic_and_ulong(3C)
atomic_and_ulong_nv(3C)
atomic_and_ushort(3C)
atomic_and_ushort_nv(3C)
atomic_bits(3C)
atomic_cas(3C)
atomic_cas_16(3C)
atomic_cas_32(3C)
atomic_cas_64(3C)
atomic_cas_8(3C)
atomic_cas_ptr(3C)
atomic_cas_uchar(3C)
atomic_cas_uint(3C)
atomic_cas_ulong(3C)
atomic_cas_ushort(3C)
atomic_clear_long_excl(3C)
atomic_dec(3C)
atomic_dec_16(3C)
atomic_dec_16_nv(3C)
atomic_dec_32(3C)
atomic_dec_32_nv(3C)
atomic_dec_64(3C)
atomic_dec_64_nv(3C)
atomic_dec_8(3C)
atomic_dec_8_nv(3C)
atomic_dec_ptr(3C)
atomic_dec_ptr_nv(3C)
atomic_dec_uchar(3C)
atomic_dec_uchar_nv(3C)
atomic_dec_uint(3C)
atomic_dec_uint_nv(3C)
atomic_dec_ulong(3C)
atomic_dec_ulong_nv(3C)
atomic_dec_ushort(3C)
atomic_dec_ushort_nv(3C)
atomic_inc(3C)
atomic_inc_16(3C)
atomic_inc_16_nv(3C)
atomic_inc_32(3C)
atomic_inc_32_nv(3C)
atomic_inc_64(3C)
atomic_inc_64_nv(3C)
atomic_inc_8(3C)
atomic_inc_8_nv(3C)
atomic_inc_ptr(3C)
atomic_inc_ptr_nv(3C)
atomic_inc_uchar(3C)
atomic_inc_uchar_nv(3C)
atomic_inc_uint(3C)
atomic_inc_uint_nv(3C)
atomic_inc_ulong(3C)
atomic_inc_ulong_nv(3C)
atomic_inc_ushort(3C)
atomic_inc_ushort_nv(3C)
atomic_ops(3C)
atomic_or(3C)
atomic_or_16(3C)
atomic_or_16_nv(3C)
atomic_or_32(3C)
atomic_or_32_nv(3C)
atomic_or_64(3C)
atomic_or_64_nv(3C)
atomic_or_8(3C)
atomic_or_8_nv(3C)
atomic_or_uchar(3C)
atomic_or_uchar_nv(3C)
atomic_or_uint(3C)
atomic_or_uint_nv(3C)
atomic_or_ulong(3C)
atomic_or_ulong_nv(3C)
atomic_or_ushort(3C)
atomic_or_ushort_nv(3C)
atomic_set_long_excl(3C)
atomic_swap(3C)
atomic_swap_16(3C)
atomic_swap_32(3C)
atomic_swap_64(3C)
atomic_swap_8(3C)
atomic_swap_ptr(3C)
atomic_swap_uchar(3C)
atomic_swap_uint(3C)
atomic_swap_ulong(3C)
atomic_swap_ushort(3C)
attropen(3C)
backtrace(3C)
backtrace_symbols(3C)
backtrace_symbols_fd(3C)
basename(3C)
bcmp(3C)
bcopy(3C)
bind_textdomain_codeset(3C)
bindtextdomain(3C)
bsd_signal(3C)
bsdmalloc(3MALLOC)
bsearch(3C)
bstring(3C)
btowc(3C)
bzero(3C)
calloc(3C)
calloc(3MALLOC)
canonicalize_file_name(3C)
catclose(3C)
catgets(3C)
catopen(3C)
cfgetispeed(3C)
cfgetospeed(3C)
cfsetispeed(3C)
cfsetospeed(3C)
cftime(3C)
chkauthattr(3C)
chkauthattr_ucred(3C)
clearenv(3C)
clearerr(3C)
clock(3C)
clock_getres(3C)
clock_gettime(3C)
clock_nanosleep(3C)
clock_settime(3C)
closedir(3C)
closefrom(3C)
closelog(3C)
cond_broadcast(3C)
cond_destroy(3C)
cond_init(3C)
cond_reltimedwait(3C)
cond_signal(3C)
cond_timedwait(3C)
cond_wait(3C)
confstr(3C)
crypt(3C)
crypt_genhash_impl(3C)
crypt_gensalt(3C)
crypt_gensalt_impl(3C)
cset(3C)
csetcol(3C)
csetlen(3C)
csetno(3C)
ctermid(3C)
ctermid_r(3C)
ctime(3C)
ctime_r(3C)
ctype(3C)
cuserid(3C)
daemon(3C)
dbm_clearerr(3C)
dbm_close(3C)
dbm_delete(3C)
dbm_error(3C)
dbm_fetch(3C)
dbm_firstkey(3C)
dbm_nextkey(3C)
dbm_open(3C)
dbm_store(3C)
dcgettext(3C)
dcngettext(3C)
decimal_to_double(3C)
decimal_to_extended(3C)
decimal_to_floating(3C)
decimal_to_quadruple(3C)
decimal_to_single(3C)
dgettext(3C)
difftime(3C)
directio(3C)
dirfd(3C)
dirname(3C)
div(3C)
dl_iterate_phdr(3C)
dladdr(3C)
dladdr1(3C)
dlclose(3C)
dldump(3C)
dlerror(3C)
dlinfo(3C)
dlmopen(3C)
dlopen(3C)
dlsym(3C)
dngettext(3C)
door_bind(3C)
door_call(3C)
door_create(3C)
door_cred(3C)
door_getparam(3C)
door_info(3C)
door_return(3C)
door_revoke(3C)
door_server_create(3C)
door_setparam(3C)
door_ucred(3C)
door_unbind(3C)
door_xcreate(3C)
double_to_decimal(3C)
drand48(3C)
dup2(3C)
econvert(3C)
ecvt(3C)
edata(3C)
enable_extended_FILE_stdio(3C)
encrypt(3C)
end(3C)
endauthattr(3C)
endexecattr(3C)
endgrent(3C)
endnetgrent(3C)
endprofattr(3C)
endpwent(3C)
endspent(3C)
enduserattr(3C)
endusershell(3C)
endutent(3C)
endutxent(3C)
erand48(3C)
err(3C)
errno(3C)
errx(3C)
etext(3C)
euccol(3C)
euclen(3C)
eucscol(3C)
exit(3C)
extended_to_decimal(3C)
fattach(3C)
fclose(3C)
fcloseall(3C)
fconvert(3C)
fcvt(3C)
FD_CLR(3C)
FD_ISSET(3C)
FD_SET(3C)
FD_ZERO(3C)
fdatasync(3C)
fdetach(3C)
fdopen(3C)
fdopendir(3C)
fdwalk(3C)
feof(3C)
ferror(3C)
fflush(3C)
ffs(3C)
ffsl(3C)
ffsll(3C)
fgetattr(3C)
fgetc(3C)
fgetgrent(3C)
fgetgrent_r(3C)
fgetpos(3C)
fgetpwent(3C)
fgetpwent_r(3C)
fgets(3C)
fgetspent(3C)
fgetspent_r(3C)
fgetuserattr(3C)
fgetwc(3C)
fgetws(3C)
file_to_decimal(3C)
fileno(3C)
finite(3C)
floating_to_decimal(3C)
flockfile(3C)
fls(3C)
flsl(3C)
flsll(3C)
fmtmsg(3C)
fnmatch(3C)
fopen(3C)
fpclass(3C)
fpgetmask(3C)
fpgetround(3C)
fpgetsticky(3C)
fprintf(3C)
fpsetmask(3C)
fpsetround(3C)
fpsetsticky(3C)
fputc(3C)
fputs(3C)
fputwc(3C)
fputws(3C)
fread(3C)
frealpath(3C)
free(3C)
free(3MALLOC)
free_authattr(3C)
free_execattr(3C)
free_profattr(3C)
free_proflist(3C)
free_userattr(3C)
freopen(3C)
fscanf(3C)
fseek(3C)
fseeko(3C)
fsetattr(3C)
fsetpos(3C)
fsync(3C)
ftell(3C)
ftello(3C)
ftime(3C)
ftok(3C)
ftruncate(3C)
ftrylockfile(3C)
ftw(3C)
func_to_decimal(3C)
funlockfile(3C)
fwide(3C)
fwprintf(3C)
fwrite(3C)
fwscanf(3C)
gconvert(3C)
gcvt(3C)
get_nprocs(3C)
get_nprocs_conf(3C)
getaccess_times (3C)
getattrat(3C)
getauthattr(3C)
getauthnam(3C)
getc(3C)
getc_unlocked(3C)
getchar(3C)
getchar_unlocked(3C)
getcpuid(3C)
getcwd(3C)
getdate(3C)
getdelim(3C)
getdtablesize(3C)
getenv(3C)
getexecattr(3C)
getexecname(3C)
getexecprof(3C)
getexecuser(3C)
getextmntent(3C)
getgrent(3C)
getgrent_r(3C)
getgrgid(3C)
getgrgid_r(3C)
getgrnam(3C)
getgrnam_r(3C)
gethomelgroup(3C)
gethostid(3C)
gethostname(3C)
gethrtime(3C)
gethrvtime(3C)
getline(3C)
getloadavg(3C)
getlogin(3C)
getlogin_r(3C)
getmntany(3C)
getmntent(3C)
getnetgrent(3C)
getnetgrent_r(3C)
getopt(3C)
getopt_clip(3C)
getopt_long(3C)
getopt_long_only(3C)
getpagesize(3C)
getpagesizes(3C)
getpass(3C)
getpassphrase(3C)
getpeerucred(3C)
getpriority(3C)
getprofattr(3C)
getproflist(3C)
getprofnam(3C)
getprogname(3C)
getpw(3C)
getpwent(3C)
getpwent_r(3C)
getpwnam(3C)
getpwnam_r(3C)
getpwuid(3C)
getpwuid_r(3C)
getrusage(3C)
gets(3C)
getspent(3C)
getspent_r(3C)
getspnam(3C)
getspnam_r(3C)
getsubopt(3C)
gettext(3C)
gettimeofday(3C)
gettxt(3C)
getuserattr(3C)
getuserattrnam(3C)
getusernam(3C)
getusershell(3C)
getuseruid(3C)
getutent(3C)
getutid(3C)
getutline(3C)
getutmp(3C)
getutmpx(3C)
getutxent(3C)
getutxid(3C)
getutxline(3C)
getvfsany(3C)
getvfsent(3C)
getvfsfile(3C)
getvfsspec(3C)
getw(3C)
getwc(3C)
getwchar(3C)
getwd(3C)
getwidth(3C)
getws(3C)
getzoneid(3C)
getzoneidbyname(3C)
getzonenamebyid(3C)
glob(3C)
globfree(3C)
gmtime(3C)
gmtime_r(3C)
grantpt(3C)
gsignal(3C)
hasmntopt(3C)
hcreate(3C)
hdestroy(3C)
hsearch(3C)
iconv(3C)
iconv_close(3C)
iconv_open(3C)
iconvctl(C)
iconvstr(3C)
imaxabs(3C)
imaxdiv(3C)
index(3C)
initgroups(3C)
initstate(3C)
innetgr(3C)
insque(3C)
is_system_labeled(3C)
isaexec(3C)
isalnum(3C)
isalpha(3C)
isascii(3C)
isastream(3C)
isatty(3C)
isblank(3C)
iscntrl(3C)
isdigit(3C)
isenglish(3C)
isgraph(3C)
isideogram(3C)
islower(3C)
isnand(3C)
isnanf(3C)
isnumber(3C)
isphonogram(3C)
isprint(3C)
ispunct(3C)
isspace(3C)
isspecial(3C)
isupper(3C)
iswalnum(3C)
iswalpha(3C)
iswascii(3C)
iswblank(3C)
iswcntrl(3C)
iswctype(3C)
iswdigit(3C)
iswgraph(3C)
iswlower(3C)
iswprint(3C)
iswpunct(3C)
iswspace(3C)
iswupper(3C)
iswxdigit(3C)
isxdigit(3C)
jrand48(3C)
killpg(3C)
kva_match(3C)
l64a(3C)
labs(3C)
lckpwdf(3C)
lcong48(3C)
ldiv(3C)
lfind(3C)
lfmt(3C)
lio_listio(3C)
llabs(3C)
lldiv(3C)
lltostr(3C)
localeconv(3C)
localelist(3C)
localelistfree(3C)
localtime(3C)
localtime_r(3C)
lockf(3C)
longjmp(3C)
lrand48(3C)
lsearch(3C)
madvise(3C)
major(3C)
makecontext(3C)
makedev(3C)
mallinfo(3MALLOC)
malloc(3C)
malloc(3MALLOC)
mallocctl(3MALLOC)
mallopt(3MALLOC)
mapmalloc(3MALLOC)
match_execattr(3C)
mblen(3C)
mbrlen(3C)
mbrtowc(3C)
mbsinit(3C)
mbsrtowcs(3C)
mbstowcs(3C)
mbtowc(3C)
memalign(3C)
memalign(3MALLOC)
membar_consumer(3C)
membar_enter(3C)
membar_exit(3C)
membar_ops(3C)
membar_producer(3C)
memccpy(3C)
memchr(3C)
memcmp(3C)
memcpy(3C)
memmem(3C)
memmove(3C)
memory(3C)
memset(3C)
minor(3C)
mkdtemp(3C)
mkfifo(3C)
mkfifoat(3C)
mkstemp(3C)
mkstemps(3C)
mktemp(3C)
mktime(3C)
mlock(3C)
mlockall(3C)
monitor(3C)
mq_close(3C)
mq_getattr(3C)
mq_notify(3C)
mq_open(3C)
mq_receive(3C)
mq_reltimedreceive_np(3C)
mq_reltimedsend_np(3C)
mq_send(3C)
mq_setattr(3C)
mq_timedreceive(3C)
mq_timedsend(3C)
mq_unlink(3C)
mrand48(3C)
msync(3C)
mtmalloc(3MALLOC)
munlock(3C)
munlockall(3C)
mutex_consistent(3C)
mutex_destroy(3C)
mutex_init(3C)
mutex_lock(3C)
mutex_trylock(3C)
mutex_unlock(3C)
nanosleep(3C)
ndbm(3C)
nftw(3C)
ngettext(3C)
nl_langinfo(3C)
nrand48(3C)
offsetof(3C)
opendir(3C)
openlog(3C)
pclose(3C)
perror(3C)
pfmt(3C)
plock(3C)
popen(3C)
port_alert(3C)
port_associate(3C)
port_create(3C)
port_dissociate(3C)
port_get(3C)
port_getn(3C)
port_send(3C)
port_sendn(3C)
posix_fadvise(3C)
posix_fallocate(3C)
posix_madvise(3C)
posix_memalign(3C)
posix_openpt(3C)
posix_spawn(3C)
posix_spawn_file_actions_addclose(3C)
posix_spawn_file_actions_addclosefrom_np(3C)
posix_spawn_file_actions_adddup2(3C)
posix_spawn_file_actions_addopen(3C)
posix_spawn_file_actions_destroy(3C)
posix_spawn_file_actions_init(3C)
posix_spawnattr_destroy(3C)
posix_spawnattr_getflags(3C)
posix_spawnattr_getpgroup(3C)
posix_spawnattr_getschedparam(3C)
posix_spawnattr_getschedpolicy(3C)
posix_spawnattr_getsigdefault(3C)
posix_spawnattr_getsigignore_np(3C)
posix_spawnattr_getsigmask(3C)
posix_spawnattr_init(3C)
posix_spawnattr_setflags(3C)
posix_spawnattr_setpgroup(3C)
posix_spawnattr_setschedparam(3C)
posix_spawnattr_setschedpolicy(3C)
posix_spawnattr_setsigdefault(3C)
posix_spawnattr_setsigignore_np(3C)
posix_spawnattr_setsigmask(3C)
posix_spawnp(3C)
printf(3C)
printstack(3C)
priv_addset(3C)
priv_allocset(3C)
priv_basicset(3C)
priv_copyset(3C)
priv_delset(3C)
priv_emptyset(3C)
priv_fillset(3C)
priv_freeset(3C)
priv_getbyname(3C)
priv_getbynum(3C)
priv_getsetbyname(3C)
priv_getsetbynum(3C)
priv_gettext(3C)
priv_ineffect(3C)
priv_intersect(3C)
priv_inverse(3C)
priv_isemptyset(3C)
priv_isequalset(3C)
priv_isfullset(3C)
priv_ismember(3C)
priv_issubset(3C)
priv_set(3C)
priv_set_to_str(3C)
priv_str_to_set(3C)
priv_union(3C)
pselect(3C)
pset_getloadavg(3C)
psiginfo(3C)
psignal(3C)
pthread_atfork(3C)
pthread_attr_destroy(3C)
pthread_attr_getdetachstate(3C)
pthread_attr_getguardsize(3C)
pthread_attr_getinheritsched(3C)
pthread_attr_getschedparam(3C)
pthread_attr_getschedpolicy(3C)
pthread_attr_getscope(3C)
pthread_attr_getstack(3C)
pthread_attr_getstackaddr(3C)
pthread_attr_getstacksize(3C)
pthread_attr_init(3C)
pthread_attr_setdetachstate(3C)
pthread_attr_setguardsize(3C)
pthread_attr_setinheritsched(3C)
pthread_attr_setschedparam(3C)
pthread_attr_setschedpolicy(3C)
pthread_attr_setscope(3C)
pthread_attr_setstack(3C)
pthread_attr_setstackaddr(3C)
pthread_attr_setstacksize(3C)
pthread_barrier_destroy(3C)
pthread_barrier_init(3C)
pthread_barrier_wait(3C)
pthread_barrierattr_destroy(3C)
pthread_barrierattr_getpshared(3C)
pthread_barrierattr_init(3C)
pthread_barrierattr_setpshared(3C)
pthread_cancel(3C)
pthread_cleanup_pop(3C)
pthread_cleanup_push(3C)
pthread_cond_broadcast(3C)
pthread_cond_destroy(3C)
pthread_cond_init(3C)
pthread_cond_reltimedwait_np(3C)
pthread_cond_signal(3C)
pthread_cond_timedwait(3C)
pthread_cond_wait(3C)
pthread_condattr_destroy(3C)
pthread_condattr_getclock(3C)
pthread_condattr_getpshared(3C)
pthread_condattr_init(3C)
pthread_condattr_setclock(3C)
pthread_condattr_setpshared(3C)
pthread_create(3C)
pthread_detach(3C)
pthread_equal(3C)
pthread_exit(3C)
pthread_getconcurrency(3C)
pthread_getschedparam(3C)
pthread_getspecific(3C)
pthread_join(3C)
pthread_key_create(3C)
pthread_key_create_once_np(3C)
pthread_key_delete(3C)
pthread_kill(3C)
pthread_mutex_consistent(3C)
pthread_mutex_destroy(3C)
pthread_mutex_getprioceiling(3C)
pthread_mutex_init(3C)
pthread_mutex_lock(3C)
pthread_mutex_reltimedlock_np(3C)
pthread_mutex_setprioceiling(3C)
pthread_mutex_timedlock(3C)
pthread_mutex_trylock(3C)
pthread_mutex_unlock(3C)
pthread_mutexattr_destroy(3C)
pthread_mutexattr_getprioceiling(3C)
pthread_mutexattr_getprotocol(3C)
pthread_mutexattr_getpshared(3C)
pthread_mutexattr_getrobust(3C)
pthread_mutexattr_gettype(3C)
pthread_mutexattr_init(3C)
pthread_mutexattr_setprioceiling(3C)
pthread_mutexattr_setprotocol(3C)
pthread_mutexattr_setpshared(3C)
pthread_mutexattr_setrobust(3C)
pthread_mutexattr_settype(3C)
pthread_once(3C)
pthread_rwlock_destroy(3C)
pthread_rwlock_init(3C)
pthread_rwlock_rdlock(3C)
pthread_rwlock_reltimedrdlock_np(3C)
pthread_rwlock_reltimedwrlock_np(3C)
pthread_rwlock_timedrdlock(3C)
pthread_rwlock_timedwrlock(3C)
pthread_rwlock_tryrdlock(3C)
pthread_rwlock_trywrlock(3C)
pthread_rwlock_unlock(3C)
pthread_rwlock_wrlock(3C)
pthread_rwlockattr_destroy(3C)
pthread_rwlockattr_getpshared(3C)
pthread_rwlockattr_init(3C)
pthread_rwlockattr_setpshared(3C)
pthread_self(3C)
pthread_setcancelstate(3C)
pthread_setcanceltype(3C)
pthread_setconcurrency(3C)
pthread_setschedparam(3C)
pthread_setschedprio(3C)
pthread_setspecific(3C)
pthread_sigmask(3C)
pthread_spin_destroy(3C)
pthread_spin_init(3C)
pthread_spin_lock(3C)
pthread_spin_trylock(3C)
pthread_spin_unlock(3C)
pthread_testcancel(3C)
ptrace(3C)
ptsname(3C)
putc(3C)
putc_unlocked(3C)
putchar(3C)
putchar_unlocked(3C)
putenv(3C)
putmntent(3C)
putpwent(3C)
puts(3C)
putspent(3C)
pututline(3C)
pututxline(3C)
putw(3C)
putwc(3C)
putwchar(3C)
putws(3C)
qeconvert(3C)
qfconvert(3C)
qgconvert(3C)
qsort(3C)
quadruple_to_decimal(3C)
raise(3C)
rand(3C)
rand_r(3C)
random(3C)
rbac_chkauth(3C)
rctl_walk(3C)
rctlblk_get_enforced_value(3C)
rctlblk_get_firing_time(3C)
rctlblk_get_global_action(3C)
rctlblk_get_global_flags(3C)
rctlblk_get_local_action(3C)
rctlblk_get_local_flags(3C)
rctlblk_get_privilege(3C)
rctlblk_get_recipient_pid(3C)
rctlblk_get_value(3C)
rctlblk_set_local_action(3C)
rctlblk_set_local_flags(3C)
rctlblk_set_privilege(3C)
rctlblk_set_recipient_pid(3C)
rctlblk_set_value(3C)
rctlblk_size(3C)
re_comp(3C)
re_exec(3C)
readdir(3C)
readdir_r(3C)
realloc(3C)
realloc(3MALLOC)
realpath(3C)
reboot(3C)
regcmp(3C)
regcomp(3C)
regerror(3C)
regex(3C)
regexec(3C)
regfree(3C)
remove(3C)
remque(3C)
resetmnttab(3C)
rewind(3C)
rewinddir(3C)
rindex(3C)
rw_rdlock(3C)
rw_tryrdlock(3C)
rw_trywrlock(3C)
rw_unlock(3C)
rw_wrlock(3C)
rwlock(3C)
rwlock_destroy(3C)
rwlock_init(3C)
scandir(3C)
scanf(3C)
sched_get_priority_max(3C)
sched_get_priority_min(3C)
sched_getparam(3C)
sched_getscheduler(3C)
sched_rr_get_interval(3C)
sched_setparam(3C)
sched_setscheduler(3C)
sched_yield(3C)
schedctl_exit(3C)
schedctl_init(3C)
schedctl_lookup(3C)
schedctl_start(3C)
schedctl_stop(3C)
seconvert(3C)
seed48(3C)
seekdir(3C)
select(3C)
sem_close(3C)
sem_destroy(3C)
sem_getvalue(3C)
sem_init(3C)
sem_open(3C)
sem_post(3C)
sem_reltimedwait_np(3C)
sem_timedwait(3C)
sem_trywait(3C)
sem_unlink(3C)
sem_wait(3C)
sema_destroy(3C)
sema_init(3C)
sema_post(3C)
sema_trywait(3C)
sema_wait(3C)
semaphore(3C)
setattrat(3C)
setauthattr(3C)
setbuf(3C)
setbuffer(3C)
setcat(3C)
setenv(3C)
setexecattr(3C)
setgrent(3C)
sethostname(3C)
setjmp(3C)
setkey(3C)
setlabel(3C)
setlinebuf(3C)
setlocale(3C)
setlogmask(3C)
setnetgrent(3C)
setpriority(3C)
setprofattr(3C)
setprogname(3C)
setpwent(3C)
setspent(3C)
setstate(3C)
settimeofday(3C)
setuserattr(3C)
setusershell(3C)
setutent(3C)
setutxent(3C)
setvbuf(3C)
sfconvert(3C)
sgconvert(3C)
shm_open(3C)
shm_unlink(3C)
sig2str(3C)
sigaddset(3C)
sigdelset(3C)
sigemptyset(3C)
sigfillset(3C)
sigfpe(3C)
sighold(3C)
sigignore(3C)
siginterrupt(3C)
sigismember(3C)
siglongjmp(3C)
signal(3C)
sigpause(3C)
sigqueue(3C)
sigrelse(3C)
sigset(3C)
sigsetjmp(3C)
sigsetops(3C)
sigstack(3C)
sigtimedwait(3C)
sigwaitinfo(3C)
single_to_decimal(3C)
sleep(3C)
smt_pause(3C)
snprintf(3C)
sprintf(3C)
srand(3C)
srand48(3C)
srandom(3C)
sscanf(3C)
ssignal(3C)
stack_getbounds(3C)
stack_inbounds(3C)
stack_setbounds(3C)
stack_violation(3C)
stdio(3C)
stpcpy(3C)
stpncpy(3C)
str2sig(3C)
strcasecmp(3C)
strcasestr(3C)
strcat(3C)
strchr(3C)
strchrnul(3C)
strcmp(3C)
strcoll(3C)
strcpy(3C)
strcspn(3C)
strdup(3C)
strdupa(3C)
strerror(3C)
strerror_r(3C)
strfmon(3C)
strftime(3C)
string(3C)
string_to_decimal(3C)
strlcat(3C)
strlcpy(3C)
strlen(3C)
strncasecmp(3C)
strncat(3C)
strncmp(3C)
strncpy(3C)
strndup(3C)
strndupa(3C)
strnlen(3C)
strnstr(3C)
strpbrk(3C)
strptime(3C)
strrchr(3C)
strsep(3C)
strsignal(3C)
strspn(3C)
strstr(3C)
strtod(3C)
strtof(3C)
strtoimax(3C)
strtok(3C)
strtok_r(3C)
strtol(3C)
strtold(3C)
strtoll(3C)
strtoul(3C)
strtoull(3C)
strtoumax(3C)
strtows(3C)
strxfrm(3C)
swab(3C)
swapcontext(3C)
swprintf(3C)
swscanf(3C)
sync_instruction_memory(3C)
sysconf(3C)
syslog(3C)
system(3C)
tcdrain(3C)
tcflow(3C)
tcflush(3C)
tcgetattr(3C)
tcgetpgrp(3C)
tcgetsid(3C)
tcsendbreak(3C)
tcsetattr(3C)
tcsetpgrp(3C)
td_event_addset(3C_DB)
td_event_delset(3C_DB)
td_event_emptyset(3C_DB)
td_event_fillset(3C_DB)
td_eventisempty(3C_DB)
td_eventismember(3C_DB)
td_init(3C_DB)
td_log(3C_DB)
td_sync_get_info(3C_DB)
td_sync_get_stats(3C_DB)
td_sync_setstate(3C_DB)
td_sync_waiters(3C_DB)
td_ta_clear_event(3C_DB)
td_ta_delete(3C_DB)
td_ta_enable_stats(3C_DB)
td_ta_event_addr(3C_DB)
td_ta_event_getmsg(3C_DB)
td_ta_get_nthreads(3C_DB)
td_ta_get_ph(3C_DB)
td_ta_get_stats(3C_DB)
td_ta_map_addr2sync(3C_DB)
td_ta_map_id2thr(3C_DB)
td_ta_map_lwp2thr(3C_DB)
td_ta_new(3C_DB)
td_ta_reset_stats(3C_DB)
td_ta_set_event(3C_DB)
td_ta_setconcurrency(3C_DB)
td_ta_sync_iter(3C_DB)
td_ta_sync_tracking_enable(3C_DB)
td_ta_thr_iter(3C_DB)
td_ta_tsd_iter(3C_DB)
td_thr_clear_event(3C_DB)
td_thr_dbresume(3C_DB)
td_thr_dbsuspend(3C_DB)
td_thr_event_enable(3C_DB)
td_thr_event_getmsg(3C_DB)
td_thr_get_info(3C_DB)
td_thr_getcxregs(3C_DB)
td_thr_getcxregsize(3C_DB)
td_thr_getfpregs(3C_DB)
td_thr_getgregs(3C_DB)
td_thr_getxregs(3C_DB)
td_thr_getxregsize(3C_DB)
td_thr_lockowner(3C_DB)
td_thr_set_event(3C_DB)
td_thr_setcxregs(3C_DB)
td_thr_setfpregs(3C_DB)
td_thr_setgregs(3C_DB)
td_thr_setprio(3C_DB)
td_thr_setsigpending(3C_DB)
td_thr_setxregs(3C_DB)
td_thr_sigsetmask(3C_DB)
td_thr_sleepinfo(3C_DB)
td_thr_tlsbase(3C_DB)
td_thr_tsd(3C_DB)
td_thr_validate(3C_DB)
tdelete(3C)
tdestroy(3C)
tell(3C)
telldir(3C)
tempnam(3C)
termios(3C)
textdomain(3C)
tfind(3C)
thr_continue(3C)
thr_create(3C)
thr_exit(3C)
thr_getconcurrency(3C)
thr_getprio(3C)
thr_getspecific(3C)
thr_join(3C)
thr_keycreate(3C)
thr_keycreate_once(3C)
thr_kill(3C)
thr_main(3C)
thr_min_stack(3C)
thr_self(3C)
thr_setconcurrency(3C)
thr_setprio(3C)
thr_setspecific(3C)
thr_sigsetmask(3C)
thr_stksegment(3C)
thr_suspend(3C)
thr_yield(3C)
timer_create(3C)
timer_delete(3C)
timer_getoverrun(3C)
timer_gettime(3C)
timer_settime(3C)
timeradd(3C)
timerclear(3C)
timercmp(3C)
timerisset(3C)
timersub(3C)
tmpfile(3C)
tmpnam(3C)
tmpnam_r(3C)
toascii(3C)
tolower(3C)
toupper(3C)
towctrans(3C)
towlower(3C)
towupper(3C)
truncate(3C)
tsearch(3C)
ttyname(3C)
ttyname_r(3C)
ttyslot(3C)
twalk(3C)
tzset(3C)
u8_strcmp(3C)
u8_textprep_str(3C)
u8_validate(3C)
ualarm(3C)
uconv_u16tou32(3C)
uconv_u16tou8(3C)
uconv_u32tou16(3C)
uconv_u32tou8(3C)
uconv_u8tou16(3C)
uconv_u8tou32(3C)
ucred_free(3C)
ucred_get(3C)
ucred_getegid(3C)
ucred_geteuid(3C)
ucred_getgroups(3C)
ucred_getlabel(3C)
ucred_getpflags(3C)
ucred_getpid(3C)
ucred_getprivset(3C)
ucred_getprojid(3C)
ucred_getrgid(3C)
ucred_getruid(3C)
ucred_getsgid(3C)
ucred_getsuid(3C)
ucred_getzoneid(3C)
ucred_size(3C)
ulckpwdf(3C)
ulltostr(3C)
umem_alloc(3MALLOC)
umem_cache_alloc(3MALLOC)
umem_cache_create(3MALLOC)
umem_cache_destroy(3MALLOC)
umem_cache_free(3MALLOC)
umem_debug(3MALLOC)
umem_free(3MALLOC)
umem_nofail_callback(3MALLOC)
umem_zalloc(3MALLOC)
ungetc(3C)
ungetwc(3C)
unlockpt(3C)
unordered(3C)
unsetenv(3C)
updwtmp(3C)
updwtmpx(3C)
usleep(3C)
utmpname(3C)
utmpxname(3C)
valloc(3C)
valloc(3MALLOC)
vasprintf(3C)
verr(3C)
verrx(3C)
vfprintf(3C)
vfscanf(3C)
vfwprintf(3C)
vfwscanf(3C)
vlfmt(3C)
vpfmt(3C)
vprintf(3C)
vscanf(3C)
vsnprintf(3C)
vsprintf(3C)
vsscanf(3C)
vswprintf(3C)
vswscanf(3C)
vsyslog(3C)
vwarn(3C)
vwarnx(3C)
vwprintf(3C)
vwscanf(3C)
wait(3C)
wait3(3C)
wait4(3C)
waitpid(3C)
walkcontext(3C)
warn(3C)
warnx(3C)
watchmalloc(3MALLOC)
watof(3C)
watoi(3C)
watol(3C)
watoll(3C)
wcpcpy(3C)
wcpncpy(3C)
wcrtomb(3C)
wcscasecmp(3C)
wcscat(3C)
wcschr(3C)
wcscmp(3C)
wcscoll(3C)
wcscpy(3C)
wcscspn(3C)
wcsdup(3C)
wcsetno(3C)
wcsftime(3C)
wcslen(3C)
wcsncasecmp(3C)
wcsncat(3C)
wcsncmp(3C)
wcsncpy(3C)
wcsnlen(3C)
wcspbrk(3C)
wcsrchr(3C)
wcsrtombs(3C)
wcsspn(3C)
wcsstr(3C)
wcstod(3C)
wcstof(3C)
wcstoimax(3C)
wcstok(3C)
wcstol(3C)
wcstold(3C)
wcstoll(3C)
wcstombs(3C)
wcstoul(3C)
wcstoull(3C)
wcstoumax(3C)
wcstring(3C)
wcswcs(3C)
wcswidth(3C)
wcsxfrm(3C)
wctob(3C)
wctomb(3C)
wctrans(3C)
wctrans_ja(3C)
wctype(3C)
wctype_ja(3C)
wcwidth(3C)
windex(3C)
wmemchr(3C)
wmemcmp(3C)
wmemcpy(3C)
wmemmove(3C)
wmemset(3C)
wordexp(3C)
wordfree(3C)
wprintf(3C)
wrindex(3C)
wscanf(3C)
wscasecmp(3C)
wscat(3C)
wschr(3C)
wscmp(3C)
wscol(3C)
wscoll(3C)
wscpy(3C)
wscspn(3C)
wsdup(3C)
wslen(3C)
wsncasecmp(3C)
wsncat(3C)
wsncmp(3C)
wsncpy(3C)
wspbrk(3C)
wsprintf(3C)
wsrchr(3C)
wsscanf(3C)
wsspn(3C)
wstod(3C)
wstok(3C)
wstol(3C)
wstostr(3C)
wstring(3C)
wsxfrm(3C)
atomic_and_8_nv(3C)
Name
atomic_and, atomic_and_8, atomic_and_uchar, atomic_and_16, atomic_and_ushort, atomic_and_32, atomic_and_uint , atomic_and_ulong, atomic_and_64, atomic_and_8_nv, atomic_and_uchar_nv, atomic_and_16_nv, atomic_and_ushort_nv, atomic_and_32_nv, atomic_and_uint_nv, atomic_and_ulong_nv, atomic_and_64_nv - atomic AND operations
Synopsis
#include <atomic.h>
void atomic_and_8(volatile uint8_t *target, uint8_t bits);
void atomic_and_uchar(volatile uchar_t *target, uchar_t bits);
void atomic_and_16(volatile uint16_t *target, uint16_t bits);
void atomic_and_ushort(volatile ushort_t *target, ushort_t bits);
void atomic_and_32(volatile uint32_t *target, uint32_t bits);
void atomic_and_uint(volatile uint_t *target, uint_t bits);
void atomic_and_ulong(volatile ulong_t *target, ulong_t bits);
void atomic_and_64(volatile uint64_t *target, uint64_t bits);
uint8_t atomic_and_8_nv(volatile uint8_t *target, uint8_t bits);
uchar_t atomic_and_uchar_nv(volatile uchar_t *target, uchar_t bits);
uint16_t atomic_and_16_nv(volatile uint16_t *target, uint16_t bits);
ushort_t atomic_and_ushort_nv(volatile ushort_t *target, ushort_t bits);
uint32_t atomic_and_32_nv(volatile uint32_t *target, uint32_t bits);
uint_t atomic_and_uint_nv(volatile uint_t *target, uint_t bits);
ulong_t atomic_and_ulong_nv(volatile ulong_t *target, ulong_t bits);
uint64_t atomic_and_64_nv(volatile uint64_t *target, uint64_t bits);
Description
These functions enable the bitwise AND of bits to the value stored in target to occur in an atomic manner.
Return Values
The *_nv() variants of these functions return the new value of target.
Errors
No errors are defined.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
atomic_add(3C), atomic_bits(3C), atomic_cas(3C), atomic_dec(3C), atomic_inc(3C), atomic_or(3C), atomic_swap(3C), membar_ops(3C), attributes(5), atomic_ops(9F)
Notes
The *_nv() variants are substantially more expensive on some platforms than the versions that do not return values. Do not use them unless you need to know the new value atomically.
