Go to main content
SPARC S7-2L Server Service Manual
Exit Print View
Updated: February 2019
Locate a Failed DIMM (Oracle ILOM)
The Oracle ILOM show faulty command displays current faults, including DIMM failures.
  1. Type show faulty at the Oracle ILOM prompt.
    The output will be similar to this example if a DIMM is faulty.
    -> show faulty
    Target              | Property          | Value
    /SP/faultmgmt/0     | fru               | /SYS/MB/CMP0/MCU1/CH0/D0
    /SP/faultmgmt/0     | timestamp         | Dec 21 16:40:56
    /SP/faultmgmt/0/    | timestamp         | Dec 21 16:40:56 faults/0
    /SP/faultmgmt/0/    | sp_detected_fault | /SYS/MB/CMP0/MCU1/CH0/D0
    faults/0            |                   | Forced fail(POST)
  2. Locate the DIMM that corresponds to the listed name.
    See DIMM FRU Names.
    In this example, /SYS/MB/CMP0/MCU1/CH0/D0 indicates the DIMM slot on the mother board that is farthest from the power supplies.
Related Information
