Go to main content
SPARC S7-2L Server Service Manual
Exit Print View
Updated: February 2019
Power On the Server (Oracle ILOM)
Note - If you are powering on the server following an emergency shutdown that was triggered by the top cover interlock switch, you must use the poweron command.
  • Type this command at the Oracle ILOM prompt.
    -> poweron
    You will see an alert message on the system console. This message indicates that the server is reset. You will also see a message indicating that the VCORE has been margined up to the value specified in the default .scr file that was previously configured. For example:
    -> start /System
Related Information
