Go to main content
SPARC S7-2L Server Service Manual
Exit Print View
Updated: February 2019
Find the Server Serial Number
You need the serial number of the server's chassis to obtain technical support for the system.
Note -  When a drive backplane or motherboard is replaced, the chassis serial number and part number might need to be programmed into the new component. This must be done in a special service mode by trained service personnel.
  • Locate the serial number using one of the following methods:
    • Read the serial number from a sticker located on the front of the server or another sticker on the side of the server.
    • At the Oracle ILOM prompt, type.
      -> show /System
      /System
         Targets:
      In the output look for a line under Properties that identifies the product serial number. For example:
      product_serial_number = BDL1026F8F
Related Information
