Go to main content
man pages section 3: Extended Library Functions, Volume 1
Exit Print View
Updated: Wednesday, July 27, 2022
archive_read_filter (3archive)
Name
archive_read_filter - archive_read_support_filter_all, archive_read_support_filter_bzip2, archive_read_support_filter_compress, archive_read_support_filter_gzip, archive_read_support_filter_lz4, archive_read_support_filter_lzma, archive_read_support_filter_none, archive_read_support_filter_rpm, archive_read_support_filter_uu, archive_read_support_filter_xz, archive_read_support_filter_zstd, archive_read_support_filter_program, functions for reading streaming archives
Synopsis
#include <archive.h>
int
archive_read_support_filter_all(struct archive *);
int
archive_read_support_filter_by_code(struct archive *, int);
int
archive_read_support_filter_bzip2(struct archive *);
int
archive_read_support_filter_compress(struct archive *);
int
archive_read_support_filter_grzip(struct archive *);
int
archive_read_support_filter_gzip(struct archive *);
int
archive_read_support_filter_lrzip(struct archive *);
int
archive_read_support_filter_lz4(struct archive *);
int
archive_read_support_filter_lzma(struct archive *);
int
archive_read_support_filter_lzop(struct archive *);
int
archive_read_support_filter_none(struct archive *);
int
archive_read_support_filter_rpm(struct archive *);
int
archive_read_support_filter_uu(struct archive *);
int
archive_read_support_filter_xz(struct archive *);
int
archive_read_support_filter_zstd(struct archive *);
int
archive_read_support_filter_program(struct archive *, const char *cmd);
int
archive_read_support_filter_program_signature(struct archive *,
const char *cmd, const void *signature, size_t signature_length);
Description
                                                 ARCHIVE_READ_FILTER(3archive)
NAME
       archive_read_support_filter_program_signature - functions for reading
       streaming archives
LIBRARY
       Streaming Archive Library (libarchive, -larchive)
SYNOPSIS
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
       int
DESCRIPTION
            archive_read_support_filter_bzip2(),
                   archive_read_support_filter_compress(),
                   archive_read_support_filter_grzip(),
                   archive_read_support_filter_gzip(),
                   archive_read_support_filter_lrzip(),
                   archive_read_support_filter_lz4(),
                   archive_read_support_filter_lzma(),
                   archive_read_support_filter_lzop(),
                   archive_read_support_filter_none(),
                   archive_read_support_filter_rpm(),
                   archive_read_support_filter_uu(),
                   archive_read_support_filter_xz(),
                   archive_read_support_filter_zstd(), Enables auto-detection
                   code and decompression support for the specified compres-
                   sion.  These functions may fall back on external programs
                   if an appropriate library was not available at build time.
                   Decompression using an external program is usually slower
                   than decompression through built-in libraries.  Note that
                   ``none'' is always enabled by default.
            archive_read_support_filter_all()
                   Enables all available decompression filters.
            archive_read_support_filter_by_code()
                   Enables a single filter specified by the filter code.  This
                   function does not work with ARCHIVE_FILTER_PROGRAM.  Note:
                   In statically-linked executables, this will cause your pro-
                   gram to include support for every filter.  If executable
                   size is a concern, you may wish to avoid using this func-
                   tion.
            archive_read_support_filter_program()
                   Data is fed through the specified external program before
                   being dearchived.  Note that this disables automatic detec-
                   tion of the compression format, so it makes no sense to
                   specify this in conjunction with any other decompression
                   option.
            archive_read_support_filter_program_signature()
                   This feeds data through the specified external program but
                   only if the initial bytes of the data match the specified
                   signature value.
RETURN VALUES
       These functions return ARCHIVE_OK if the compression is fully sup-
       ported, ARCHIVE_WARN if the compression is supported only through an
       external program.
       archive_read_support_filter_none() always succeeds.
ERRORS
       Detailed error codes and textual descriptions are available from the
       archive_errno() and archive_error_string() functions.
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |  ATTRIBUTE VALUE   |
       |Availability   | library/libarchive |
       |Stability      | Uncommitted        |
SEE ALSO
       archive_read(3), archive_read_data(3), archive_read_format(3), ar-
       chive_read_format(3), libarchive(3)
NOTES
       Source code for open source software components in Oracle Solaris can
       be found at https://www.oracle.com/downloads/opensource/solaris-source-
       code-downloads.html.
       This software was built from source available at
       https://github.com/oracle/solaris-userland.  The original community
       source was downloaded from
       https://github.com/libarchive/libarchive/releases/down-
       load/v3.6.1/libarchive-3.6.1.tar.gz.
       Further information about this software can be found on the open source
       community website at http://www.libarchive.org/.
                                 June 9, 2020
