Understanding the Installation
Understanding Management and Power Cabling
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the Name of the Configuration File
Enable or Disable Trap Generation on an Interface
Enable or Disable the Incremental Save Flag
Enable or Disable the Auto Save Flag
Save the Configuration to a File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Copy a System Log to a Remote Location
Configuring the Switching Feature
Configuring the Routing Feature
Check Switch Status (Oracle ILOM)
This task describes how to configure the IP address for sending and receiving the packets.
See Connect to SEFOS.
SEFOS-1# configure terminal
SEFOS-1(config)# interface vlan 1
Note - You must shut down the interface before you can configure the IP address for that interface.
SEFOS-1(config-if)# shutdown
SEFOS-1(config-if)# ip address 12.0.0.1 255.0.0.0
SEFOS-1(config-if)# no shutdown
SEFOS-1(config)# end
SEFOS-1# show ip interface vlan1 is up, line protocol is up Internet Address is 12.0.0.1/8 Broadcast Address 12.255.255.255
